mrf0ster
Hello all,
I am not sure if this is normal behavior or not. The Issue I have experienced is when I set routing policies under my VPN connection to activate the kill switch, I notice that when I do a speed test when connected to VPN on my PC, my download speeds reduce significantly.
For example, when the routing policy is not activated but I have connected to my VPN, I get a healthy 60 to 70 MB download speed. (In Australia that’s good lol.) But when I have the routing Policy section activated, my download speeds reduce significantly on the VPN devices (i.e. 5 MB download speed)
Example of 2 separate setups that slows the VPN Significantly:
SETUP1_Slow_DLS: (5MB)
Description: Source IP: Destination IP: Iface:
All Devices 192.168.0.0/24 0.0.0.0 VPN
PS4 192.168.0.156 0.0.0.0 WAN
Spare_PC 192.168.0.155 0.0.0.0 WAN
SETUP2_Slow_DLS: (5MB)
MY_PC_NIC1: 192.168.0.31 0.0.0.0 VPN
MY_PC_NIC2: 192.168.0.30 0.0.0.0 VPN
All_Other_Devices 192.168.0.0/24 0.0.0.0 WAN
SETUP3_FAST_DLS: (65mb)
There is nothing unusual happening in the LOGS that I can see, so again I am not sure if this is expected because of tunneling perhaps? (I think that’s the right terminology)
It is almost like if you have more than 1 entry, something appears to go a little a awry when balancing the 2 different options?
Thanks in advance for any advice or suggestions.
Cheers Mark
Cheers Mark
