PSA: The location of the Onedrive download folders have moved
RMerlin
Asuswrt-Merlin dev
What does PSA mean?
Thank you. Search was bringing only negative medical hits.
Now i can’t access it anymore in my onedrive app.
The links still work (post 1).
Using latest Mozilla Firefox web browser (123.0 64-bit), the url https://www.asuswrt-merlin.net/test-builds doesn't work in the sense that it resolves to a https://login.microsoftonline.com/b8045a7b-48e4-455c-ae82-8c3ab7c25bad/oauth2/authorize? url with many parameters that I have removed, and requires logging in like in the following screenshot:
However, using latest Vivaldi web browser (6.6.3271.48 64 bit) which is Chromium based, the same url https://www.asuswrt-merlin.net/test-builds works and resolves correctly to https://lostrealm-my.sharepoint.com/personal/merlin_lostrealm_ca/_layouts/15/onedrive.aspx?id=%2Fpersonal%2Fmerlin_lostrealm_ca%2FDocuments%2FAsuswrt-Merlin%2FTest%20builds&ga=1 url. Using this url works in Firefox also.
Disregard the above, starting Firefox in Troubleshoot mode... (i.e. with extensions disabled), the url works as expected. The culprit in my case was the NoScript extension.
Sorry for the erroneous information above.
More information, the above problem is caused by the Cross-tab identity leak protection in NoScript extension, which in my case was loaded anonymously by default; loading it normally restores the functionality.
To get the prompt and select Load normally, I had to open the NoScript's Options..., go to Advanced tab, select Prompt before anonymizing any request option and open https://asuswrt-merlin.net/test-builds url.
Then I went back to NoScript's Options... and changed the option to the previously selected one, Prompt before anonymizing POST submissions. Doing this meant that the original problem would occur after restarting Firefox.
If selecting Load anonymously at the prompt, a subsequent try to open https://asuswrt-merlin.net/test-builds url will not open a new prompt. To get it back I had to click the Forget decisions button for the Cross-tab identity leak protection option.
CaptnDanLKW PSA - Check TrendMicro Signature Asuswrt-Merlin 13
