Running Asus Merlin RT-AX88U 3004.388.7
I have found that when using SkyNet and Diversion that in my case I seemingly have to choose for one or the other. Running both at the same time does not seem to be possible.
1. I install Skynet, I have my DNS servers settings in the LAN DHCP server section. Result. Perfect, Skynet runs. If I use menu [3] Malware blacklist. [1] Update I see :-
Downloading filter.list | [0s]
Refreshing Whitelists | [5s]
Consolidating Blacklist | [4s]
Filtering IPv4 Addresses | [0s]
Filtering IPv4 Ranges | [0s]
Applying New Blacklist | [1s]
Refreshing AiProtect Bans | [11s]
Saving Changes | [0s]
However. If I move my DNS settings to the WAN, WAN DNS Settings, in DNS server - Assign section. If I now use menu [3] Malware blacklist. [1] Update I see :-
Downloading filter.list | [15s]
Refreshing Whitelists | [165s]
Consolidating Blacklist | curl: (2) no URL specified
curl: try 'curl --help' for more information [4s]
[*] List Content Error Detected - Stopping Banmalware
So conclusion. Diversion works great with my DNS settings in the LAN section, but not when in the WAN section.
Now we come to Diversion.
It is the exact opposite. Diversion works great with the my DNS settings in the WAN section, but does not work with the DNS settings in the LAN section ( this is explicitly mentioned when installing Diversion)
So final conclusion. It appears that Skynet and Diversion cannot be used together when a custom DNS is installed, but both do work when an IP such as googles 8.8.8.8 is used. So is there a workaround?, or do I have to choose which one to use?
