Adamm
Part of the Furniture
Sure... as above (which works great if you start it with an absolute path aka /jffs/scripts/firewall...)
Thanks nice bug, its because in two functions (banmalware and search malware) where I download multiple files (aka lists) I cd to certain directories and never swap back to the CWD, in 99% of cases this is fine (you managed to find the 1% where it isn't
You'll get a big screen load of results. Which is great. But immediately then it will regen the menu without a pause, which is a long page of text. A more 'standard behaviour' would be if it paused before the menu respawn.
Okay makes much more sense now. I was conflicted between speed/usability when reloading the menu after a previous command is completed. I guess a fake read prompt in there wouldn't hurt and making the user aware they need to press enter to continue. I'll work on something.
Not showing up on a list... Is that a case of the IP getting 'cleared' from the external list but not updated in the local blacklist yet?
That is probably the case, the lists banmalware sources from are dynamic so lets say the banmalware function was run 12 hours ago, the same IP's may not be banned on current iterations of the lists which the "stats search malware" gets its info from.
