ScenicView
Thanks! Eventually I'll have a better idea what this means. So it seems ok to whitelist in Skynet? Maybe just the apps phoning home to check for updates?
One other question. I noticed that after turning on Skynet that I'm not getting any hits on aiProtect. Can I take that to mean that nothing is making it through Skynet to aiProtect so far?
What router?I noticed that after turning on Skynet that I'm not getting any hits on aiProtect.
What router?
I do get Two-Way IPS hits on AC56U and AC68U, but not on AC86U.
All routers have 2.068, last updated last month.If you are not getting hits its probably a signature issue or something, works fine on my AC86U.
What router?
IIRC last I checked traffic was hitting AiProtect first before IPTables rules took effect. Can't say I looked into it too much as there's no great way to test. In any case both work together seamlessly, I generally get about 5 hits per day on average from AiProtect logs.
Hi Adamm
should I be concerned on the error message below? Thank you
Skynet: [INFO] Lock File Detected (save) (pid=6718) - Exiting (cpid=6911)
Skynet currently don’t support ipv6. Only ipv4Skynet filter/ block ipv6 like ipv4 ?
Would there be a way of capturing which apps are involved in the top 10 or 20 outbound / inbound blocks?
Hi Adam Im on 6.1.8. I noticed that Im getting only INBOUND blocks - no OUTBOUND.
Anyone else experiencing this?
Thanks Adam I had both selected and yes with Bit Torrent download I am seeing OUTBOUND blocking. Thank youYou may only have inbound filtering enabled, use the install command and make sure you select "All Traffic". Besides that, outbound blocks aren't as common unless you use things like P2P (torrenting).
We use essential cookies to make this site work, and optional cookies to enhance your experience.
