Double duh on my partIsn’t brute force protection only for WAN access (1)?
Did you ever actually double check the nvram values?
sshd_bfp=1
sshd_pass=0
sshd_forwarding=0
sshd_port=22
sshd_enable=1
Bit I did see that a closed source module does something with sshd_enable
release/src/router/cfg_mnt/prebuild/RT-AC68U/cfg_server matches
Double duh on my part....I assumed is was Off, LAN, LAN+WAN (0,1,2)....not Off, LAN+WAN,LAN....
service restart_firewall
iptables -S
post the output of the iptables command
sshd_bfp=1
sshd_pass=0
sshd_forwarding=0
sshd_port=22
sshd_enable=1
-P INPUT ACCEPT
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-N ACCESS_RESTRICTION
-N FUPNP
-N INPUT_ICMP
-N OVPN
-N PControls
-N PTCSRVLAN
-N PTCSRVWAN
-N SECURITY
-N default_block
-N logaccept
-N logdrop
-N other2wan
-A INPUT -p tcp -m tcp --dport 443 -j ACCEPT
-A INPUT -i ppp0 -p icmp -m icmp --icmp-type 8 -j logdrop
-A INPUT -i vlan2 -p icmp -m icmp --icmp-type 8 -j logdrop
-A INPUT -i vlan3 -p icmp -m icmp --icmp-type 8 -j logdrop
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -m state --state INVALID -j logdrop
-A INPUT ! -i br0 -j PTCSRVWAN
-A INPUT -i br0 -j PTCSRVLAN
-A INPUT -i br0 -m state --state NEW -j ACCEPT
-A INPUT -i lo -m state --state NEW -j ACCEPT
-A INPUT -m state --state NEW -j OVPN
-A INPUT -d 224.0.0.0/4 -p igmp -j ACCEPT
-A INPUT -d 224.0.0.0/4 -p udp -m udp ! --dport 1900 -j ACCEPT
-A INPUT -s 10.0.0.0/8 -i ppp0 -j DROP
-A INPUT -s 172.16.0.0/255.255.15.0 -i ppp0 -j DROP
-A INPUT -s 172.16.0.0/255.255.15.0 -i vlan2 -j ACCEPT
-A INPUT -s X.X.X.X/32 -i vlan3 -j ACCEPT
-A INPUT -p udp -m udp --sport 67 --dport 68 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 21 -j ACCEPT
-A INPUT -p icmp -j INPUT_ICMP
-A INPUT -j logdrop
-A FORWARD -d 224.0.0.0/4 -p udp -j ACCEPT
-A FORWARD -p tcp -m tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD ! -i br0 -o ppp0 -j other2wan
-A FORWARD ! -i br0 -o vlan6 -j other2wan
-A FORWARD ! -i br0 -o vlan2 -j other2wan
-A FORWARD ! -i br0 -o vlan3 -j other2wan
-A FORWARD -m state --state INVALID -j logdrop
-A FORWARD -i br0 -o br0 -j ACCEPT
-A FORWARD -i ppp0 -j SECURITY
-A FORWARD -i vlan2 -j SECURITY
-A FORWARD -i vlan3 -j SECURITY
-A FORWARD -m conntrack --ctstate DNAT -j ACCEPT
-A FORWARD -m state --state NEW -j OVPN
-A FUPNP -d 192.168.1.4/32 -p udp -m udp --dport 9308 -j ACCEPT
-A INPUT_ICMP -p icmp -m icmp --icmp-type 8 -j RETURN
-A INPUT_ICMP -p icmp -m icmp --icmp-type 13 -j RETURN
-A INPUT_ICMP -p icmp -j ACCEPT
-A OVPN -i tun21 -j ACCEPT
-A PControls -j ACCEPT
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -m limit --limit 1/sec -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK SYN -j logdrop
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -m limit --limit 1/sec -j RETURN
-A SECURITY -p tcp -m tcp --tcp-flags FIN,SYN,RST,ACK RST -j logdrop
-A SECURITY -p icmp -m icmp --icmp-type 8 -m limit --limit 1/sec -j RETURN
-A SECURITY -p icmp -m icmp --icmp-type 8 -j logdrop
-A SECURITY -j RETURN
-A logaccept -m state --state NEW -j LOG --log-prefix "ACCEPT " --log-tcp-sequence --log-tcp-options --log-ip-options
-A logaccept -j ACCEPT
-A logdrop -j DROP
-A other2wan -i tun+ -j RETURN
-A other2wan -j logdrop
@rromeroa
I may be on to something.....are you using the option to restrict router access to certain IPs? If you are, give it a try with that turned off.
That makes two of usBravo @john9527, I have IPTV Movistar enabled, didn't know that limitation...
I didn't know of either of the two I listed until I went through the code. Learn something new every day.
Now, I don't know what @Adamm will need to do with this info.
EDIT: Thanks for providing all data we asked for....the 'iptables -S' output helped me to track it down.
Nice work tracking it down, is there a nvram value for when its enabled?
if ((nvram_get_int("switch_stb_x") > 6 &&
nvram_match("switch_wantag", "movistar")))
You want iptables. This script does not control port options.ok, i am new to this, gonna update to merlin to test it out, but can some1 point me to the right direction?
as an example
i have forwarded my port 5000 to my internal lan, so i can assess my synology system
but i see in my DSM logs, that there are other ip from other countries block after x retries
so i want to setup that only access is granted to port 5000 from a specific country
how can i do this?
Nov 26 14:23:03 Skynet: [%] Startup Initiated... ( skynetloc=/tmp/mnt/EXT2/skynet )
Nov 26 14:23:15 Skynet: [*] Connection Error Detected - Exiting
server=/pool.ntp.org/1.1.1.1
/jffs/scripts/firewall-start
Not sure how bouncing before a reboot would help since dnsmasq.conf will be wiped and freshly created on boot, but the error means that skynet could not ping google.com or github.com after 4 tries.RESOLVED-Re-installed and all is well.
Hey @Adamm I have a new problem I'm not sure how to fix. Skynet fails to start on a reboot. The last two log entries are:
The only thing I altered was adding this line to dnsmasq.conf.add:Code:Nov 26 14:23:03 Skynet: [%] Startup Initiated... ( skynetloc=/tmp/mnt/EXT2/skynet ) Nov 26 14:23:15 Skynet: [*] Connection Error Detected - Exiting
I can start Skynet by launching:Code:server=/pool.ntp.org/1.1.1.1
If @Adamm is busy anyone with a clue please reply! Thanks in advance you all!Code:/jffs/scripts/firewall-start
100% Resolved
This issue was likely caused by me not bouncing dnsmasq before the reboot after I made the addition to the dnsmasq.conf.add.
as an example
how can i do this?
It's all right, thank you @Adamm... I'm sure there are more spanish users who will appreciate itI pushed a fix for movistar users (aka you)
Welcome To SNBForums
