Skynet Skynet - Router Firewall & Security Enhancements
Is it possible for skynet to block all IP ranges that are not on the whilelist? For example, I only want to whitelist Canadian and American IP ranges but block everything else.
Unfortunately not, I personally find the internet is too globally connected now for such a solution to work reliably. It would cause more issues then its worth honestly.
I have another question, i used to have upnp up and working, but now it always leaves a message saying it couldn't open a port. (DOn't have the log now)
I have since decided that i really don't need upnp on my net, so i turned it off. Does the Skynet iptable rules stop upnp from working?
I have 398.9 on my AX88.
I have the latest SkyNET and amtm installed along with entware. (if that makes a difference)
Hi Adam
When I use IOT Blocking and execute otion 3 "List Blocked devices" it actually lists all devices NOT Blocked rather than devices that are blocked. Eg My Iphone 7 - Can you confirm this?
Actually its inconsistent as I went to unblock 1 of the IP addresses that I had previously blocked and that IP Address failed to appear in the list when selecting option 3 "list blocked devices"
No, Skynet doesn't interfere with UPNP at all.
Hi Adam
This function lists all your devices and shows in a table column weather each is blocked or not.
As you can see here, my CCTV system is the only blocked device which reflects my settings.
Hi Adam
None of my other IOT devices that I have blocked appear in this list - they are all light globes starting with ESP eg
ESP_E102E1    192.168.2.63
36 / 43 Mbps
-70 dBm    23:13:53    n    _ST_AU_
BC:DD:C2:E1:16:6D
ESP_E1166D    192.168.2.201
1 / 52 Mbps
BC:DD:C2:E1:12:D6
ESP_E112D6    192.168.2.205
36 / 72 Mbps
-63 dBm    23:13:53    n    _ST_AU_
60:01:94:A1:C3:23
ESP_A1C323    192.168.2.50
24 / 52 Mbps
-63 dBm    28:42:05    n    _ST_AU_
DC:4F:22:23:B7:1A
ESP_23B71A    192.168.2.103
18 / 72 Mbps
-65 dBm    28:43:13    n    _ST_AU_
BC:DD:C2:E0:5D:44
ESP_E05D44    192.168.2.42
18 / 65 Mbps
-64 dBm    28:43:14    n    _ST_AU_
BC:DD:C2:E0:5E:80
ESP_E05E80    192.168.2.190
1 / 43 Mbps
-70 dBm    28:43:15    n    _ST_AU_
BC:DD:C2:E0:2B:47
| Device Name |                          | | Local IP |     | | MAC Address |      | | Status |
IPHONE-7                                 | 192.168.2.244    | 20:ee:28:f0:11:f2    | Unblocked
MT7681                                   | 192.168.2.27     | 28:f3:66:e9:4f:15    | Unblocked
iPhone6                                  | 192.168.2.51     | Unknown              | Unblocked
Unknown                                  | 192.168.2.73     | 00:05:fe:85:23:55    | Blocked
amazon-ddc7438e8                         | 192.168.3.56     | Unknown              | Blocked
LinksysPAP                               | 192.168.2.54     | Unknown              | Unblocked
amazon-06802718a                         | 192.168.3.175    | Unknown              | Blocked
amazon-d869a9f78                         | 192.168.3.186    | Unknown              | Blocked
surfacepc                                | 192.168.2.119    | 50:1a:c5:f6:9a:85    | Unblocked
amazon-c16dc9d27                         | 192.168.3.192    | 6c:56:97:dc:67:ea    | Blocked
Chromecast                               | 192.168.3.201    | 6c:ad:f8:f5:e7:41    | Blocked
ESP_13C0EA                               | 192.168.3.10     | 60:01:94:13:c0:ea    | Blocked
Ring                                     | 192.168.2.35     | Unknown              | Unblocked
FLIPSSURFACE                             | 192.168.2.76     | Unknown              | Unblocked
COM-MID1                                 | 192.168.4.75     | bc:30:7e:04:00:bb    | Blocked
Chromecast_5Ghz                          | 192.168.2.143    | 54:60:09:7c:93:9e    | Blocked
Unknown                                  | 192.168.2.200    | 7c:2f:80:b5:b8:ed    | Unblocked
Hi Adam
None of my other IOT devices that I have blocked appear in this list - they are all light globes eg
Skynet generates this data based on output from the following command;
ip neigh
I see 9 blocked devices in your output, how many are missing?
about 9
Adam
This is the Output from skynet.ipset showing all IOT blocked devices - therefore 10 devices missing from list output using ip neigh
create Skynet-IOT hash:net family inet hashsize 1024 maxelem 65536 comment
add Skynet-IOT 192.168.2.143 comment "IOTBan: Mar 09 11:10:34"
add Skynet-IOT 192.168.2.201 comment "IOTBan: Mar 09 10:25:13"
add Skynet-IOT 192.168.2.63 comment "IOTBan: Mar 09 10:22:29"
add Skynet-IOT 192.168.2.189 comment "IOTBan: Mar 09 10:22:29"
add Skynet-IOT 192.168.2.73 comment "IOTBan: Mar 09 11:49:10"
add Skynet-IOT 192.168.2.50 comment "IOTBan: Mar 09 10:22:29"
add Skynet-IOT 192.168.4.75 comment "IOTBan: Mar 09 11:26:46"
add Skynet-IOT 192.168.2.56 comment "IOTBan: Mar 09 09:58:48"
add Skynet-IOT 192.168.2.103 comment "IOTBan: Mar 09 10:22:29"
add Skynet-IOT 192.168.3.201 comment "IOTBan: Mar 09 10:30:00"
add Skynet-IOT 192.168.3.10 comment "IOTBan: Mar 09 11:06:44"
add Skynet-IOT 192.168.3.175 comment "IOTBan: Mar 09 11:10:34"
add Skynet-IOT 192.168.3.186 comment "IOTBan: Mar 09 11:07:59"
add Skynet-IOT 192.168.2.42 comment "IOTBan: Mar 09 09:58:48"
add Skynet-IOT 192.168.3.192 comment "IOTBan: Mar 09 11:10:34"
add Skynet-IOT 192.168.2.205 comment "IOTBan: Mar 09 10:22:29"
add Skynet-IOT 192.168.3.56 comment "IOTBan: Mar 09 11:10:34"
add Skynet-IOT 192.168.2.163 comment "IOTBan: Mar 09 09:58:48"
add Skynet-IOT 192.168.2.190 comment "IOTBan: Mar 09 09:58:48"
Adam
Perhaps these devices haven't connected to the internet in a long period of time so the connection is no longer considered active? Is this causing any issues on these devices or are you just concerned visually?
No Just visually - not a big deal - actually some of the lights have just come on - on a schedule- and I reran list and now only a few are missing
iPhone6                                  | 192.168.2.51     | 74:1b:b2:76:f0:98    | Unblocked
amazon-ddc7438e8                         | 192.168.3.56     | 78:e1:03:c0:35:fb    | Blocked
ESP_23B71A                               | 192.168.2.103    | dc:4f:22:23:b7:1a    | Blocked
amazon-06802718a                         | 192.168.3.175    | fc:a1:83:ae:45:99    | Blocked
amazon-d869a9f78                         | 192.168.3.186    | 18:74:2e:9a:d2:bd    | Blocked
ESP_E05D44                               | 192.168.2.42     | bc:dd:c2:e0:5d:44    | Blocked
ESP_E05E80                               | 192.168.2.190    | bc:dd:c2:e0:5e:80    | Blocked
Ring                                     | 192.168.2.35     | 0c:b2:b7:61:a4:a6    | Unblocked
ESP_E02B47                               | 192.168.2.163    | bc:dd:c2:e0:2b:47    | Blocked
Okay well the best I can tell you is that Skynet appears to be working fine, im sure there's a valid reason these devices aren't visually showing up.
sure - no problem - thanks for a great script
In Skynet's Settings (Option 11), Option 5 is "Unban PrivateIP", and mine is Enabled by default.
What does it do? I've searched using Google and on the forum without finding an answer.
Its a failsafe that regularly scans blocked entries for anything that shouldn't be there which would cause connection issues.
