Skynet Skynet - Router Firewall & Security Enhancements
How do you enter that number of country codes into the script? PuTTY limits my character input when I'm at the 'Input Country Abbreviations To Ban' command. I can only type up to "SA".
I’ve never used Putty before so I’m not sure. I have no issue with using my default Terminal app in MacOS.
Hi! I want to block certain site that no one can't enter tried, outbound and inbound, browser, ftp, all ports.
sh /jffs/scripts/firewall ban domain rn-tv.com
and all other possible not working still opening the site.
Did you flush the cache of the browser you were using? Did you try rebooting the router and the device before seeing if it was actually blocked?
:cool: haha I thought the same thing. 34 countries banned here yet suprisingly it hasn't broken my net, nor gaming. If you want a laugh ban these countries and load up Watchdogs 2 on PS4 and see how many outbound blocks you get to all the shadiest countries. Guessing their online play operates p2p and it's hitting the ip addresses of other players as opposed to only the ip of a central server.
af br cd cu ee eg et il iq ir kp kw ky kz lb md ng pk ps qa ru sa sb sd so ss sy tr ua ug vn ye zw cn
It's an UbiSoft game.
Voice chat is P2P. Same with Both Division games and For Honor. Pissed a lot of streamers off because one could possibly find out their ISP IP and DDoS them.
I suspect a configuration issue with putty ???
Else use 'Xshell 6' which is free for Home/School use and works perfectly. [www.netsarang.com].
(As used by 'thelonelycoder' .... See https://diversion.ch/diversion/use/development-tools.html)
I am able to copy the full list and paste it into the input with no problems !!!
Definitely sounds like a terminal issue, I also use Xshell fine and have no limited amount of character input.
Thats because cloudflare is whitelisted by default as its a CDN provider.
skynet@RT-AX88U-DC28:/tmp/home/root# nslookup rn-tv.com
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 104.28.2.47
Address 2: 104.28.3.47
Address 3: 2606:4700:30::681c:32f
Address 4: 2606:4700:30::681c:22f
skynet@RT-AX88U-DC28:/tmp/home/root# firewall stats search ip 104.28.2.47
#                     _____ _                     _             __                      #
#                    / ____| |                   | |           / /                      #
#                   | (___ | | ___   _ _ __   ___| |_  __   __/ /_                      #
#                    \___ \| |/ / | | | '_ \ / _ \ __| \ \ / / '_ \                     #
#                    ____) |   <| |_| | | | |  __/ |_   \ V /| (_) |                    #
#                   |_____/|_|\_\\__, |_| |_|\___|\__|   \_/  \___/                     #
#                                 __/ |                                                #
#                                |___/                                                  #
## - 17/03/2019 -           Asus Firewall Addition By Adamm v6.8.2                    #
##                   https://github.com/Adamm00/IPSet_ASUS                            #
[i] Debug Data Detected in /tmp/mnt/USB/skynet/skynet.log - 996.0K
[i] Monitoring From Mar 16 18:58:56 To Mar 17 13:31:55
[i] 4268 Block Events Detected
[i] 652 Unique IPs
[i] 1 Manual Bans Issued
104.28.2.47 is in set Skynet-Whitelist.
104.28.2.47 is NOT in set Skynet-Blacklist.
104.28.2.47 is NOT in set Skynet-BlockedRanges.
Whitelist Reason;
Associated Domain(s);
rn-tv.com
[i] IP Location - Canada (Cloudflare, Inc. / AS13335)
Is there any way to remove the formatting from the stats output?
I am running commands to the router using plink and dumping them to a txt file for easier checking of things.
Thing is it chokes on color formatting.
[1;31mTop 10 Blocks (Inbound);[0m
| Hits |   | | IP Address |       | | AlienVault |                                          | | Ban Reason |                                | | Associated Domains |
[1;32m-*-[0m[1;32m--*[0m   [1;32m*--[0m3x         | 92.118.37.61    (GR) | https://otx.alienvault.com/indicator/ip/92.118.37.61    | BanMalware: normshield_high_attack.ipset      |
[1;32m-*-[0m[1;32m--*[0m   [1;32m*--[0m2x         | 185.176.27.110  (BG) | https://otx.alienvault.com/indicator/ip/185.176.27.110  | BanMalware: blocklist_net_ua.ipset            |
[1;32m-*-[0m[1;32m--*[0m2x         | 130.117.72.42   (NL) | https://otx.alienvault.com/indicator/ip/130.117.72.42   | BanMalware: firehol_level3.netset             |
   [1;32m*--[0m[1;32m-*-[0m1x         | 92.63.196.17    (RU) | https://otx.alienvault.com/indicator/ip/92.63.196.17    | BanMalware: normshield_high_attack.ipset      |
[1;32m--*[0m   [1;32m*--[0m[1;32m-*-[0m1x         | 92.118.37.91    (GR) | https://otx.alienvault.com/indicator/ip/92.118.37.91    | BanMalware: normshield_high_attack.ipset      |
[1;32m--*[0m   [1;32m*--[0m[1;32m-*-[0m1x         | 92.118.37.38    (GR) | https://otx.alienvault.com/indicator/ip/92.118.37.38    | BanMalware: normshield_high_attack.ipset      |
[1;32m--*[0m   [1;32m*--[0m[1;32m-*-[0m[1;32m--*[0m1x         | 92.118.37.35    (GR) | https://otx.alienvault.com/indicator/ip/92.118.37.35    | BanMalware: normshield_high_attack.ipset      |
   [1;32m*--[0m[1;32m-*-[0m1x         | 89.248.162.168  (NL) | https://otx.alienvault.com/indicator/ip/89.248.162.168  | BanMalware: normshield_high_attack.ipset      |
[1;32m--*[0m   [1;32m*--[0m[1;32m-*-[0m1x         | 88.204.240.248  (KZ) | https://otx.alienvault.com/indicator/ip/88.204.240.248  | BanMalware: taichung.ipset                    |
[1;32m--*[0m   [1;32m*--[0m[1;32m-*-[0m1x         | 81.22.45.231    (DE) | https://otx.alienvault.com/indicator/ip/81.22.45.231    | BanMalware: alienvault_reputation.ipset       |
Yes, see this post from Adamm.
https://www.snbforums.com/threads/r...urity-enhancements.16798/page-210#post-468351
Almost works. Still get some crazyness.
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
2x         | 81.22.45.231    (DE) | https://otx.alienvault.com/indicator/ip/81.22.45.231    | BanMalware: alienvault_reputation.ipset       |
[1;32m-*-
[1;32m--*
2x         | 81.22.45.193    (DE) | https://otx.alienvault.com/indicator/ip/81.22.45.193    | BanMalware: alienvault_reputation.ipset       |
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
1x         | 92.63.197.100   (UA) | https://otx.alienvault.com/indicator/ip/92.63.197.100   | BanMalware: normshield_high_bruteforce.ipset  |
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
1x         | 92.118.37.81    (GR) | https://otx.alienvault.com/indicator/ip/92.118.37.81    | BanMalware: firehol_level3.netset             |
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
[1;32m*--
[1;32m-*-
[1;32m--*
Darn, something changed since that post, I tried back then just to learn. Now it is above my pay grade, so someone else will know. :)
Make sure you are using the exact command;
skynet@RT-AX88U-DC28:/tmp/home/root# sh /jffs/scripts/firewall stats | sed -r 's/'$(echo -e "\033")'\[[0-9]{1,2}(;([0-9]{1,2})?)?[mK]//g' | strings
[?7l
[J#############################################################################################################
#                     _____ _                     _             __                      #
#                                 __/ |                                                 #
#                                |___/                                                  #
-snip-
Last 10 Unique Connections Blocked (Inbound);
92.118.37.47    (GR) | https://otx.alienvault.com/indicator/ip/92.118.37.47    | BanMalware: normshield_high_attack.ipset      |
88.214.26.55    (SC) | https://otx.alienvault.com/indicator/ip/88.214.26.55    | BanMalware: firehol_level3.netset*            |
185.254.122.12  (LT) | https://otx.alienvault.com/indicator/ip/185.254.122.12  | BanMalware: firehol_level3.netset*            |
193.32.160.35   (NL) | https://otx.alienvault.com/indicator/ip/193.32.160.35   | BanMalware: alienvault_reputation.ipset       |
185.153.196.142 (MD) | https://otx.alienvault.com/indicator/ip/185.153.196.142 | BanMalware: firehol_level3.netset*            |
185.176.27.118  (BG) | https://otx.alienvault.com/indicator/ip/185.176.27.118  | BanMalware: normshield_high_attack.ipset      |
5.188.206.34    (BG) | https://otx.alienvault.com/indicator/ip/5.188.206.34    | BanMalware: firehol_level3.netset*            |
185.25.204.80   (IT) | https://otx.alienvault.com/indicator/ip/185.25.204.80   | BanMalware: taichung.ipset                    |
107.170.203.150 (US) | https://otx.alienvault.com/indicator/ip/107.170.203.150 | BanMalware: taichung.ipset                    |
81.22.45.228    (DE) | https://otx.alienvault.com/indicator/ip/81.22.45.228    | BanMalware: spamhaus_edrop.netset*            |
Last 10 Unique Connections Blocked (Outbound);
8.8.8.8         (US) | https://otx.alienvault.com/indicator/ip/8.8.8.8         | ManualBan: ffffffffffffffffffffffffffffffffff |
Last 10 Manual Bans;
Last 10 Unique HTTP(s) Blocks (Outbound);
Top 10 HTTP(s) Blocks (Outbound);
986x       | 185.254.122.12  (LT) | https://otx.alienvault.com/indicator/ip/185.254.122.12  | BanMalware: firehol_level3.netset*            |
779x       | 193.32.160.35   (NL) | https://otx.alienvault.com/indicator/ip/193.32.160.35   | BanMalware: alienvault_reputation.ipset       |
533x       | 88.214.26.55    (SC) | https://otx.alienvault.com/indicator/ip/88.214.26.55    | BanMalware: firehol_level3.netset*            |
339x       | 5.188.206.34    (BG) | https://otx.alienvault.com/indicator/ip/5.188.206.34    | BanMalware: firehol_level3.netset*            |
88x        | 81.22.45.184    (DE) | https://otx.alienvault.com/indicator/ip/81.22.45.184    | BanMalware: normshield_high_attack.ipset      |
70x        | 81.22.45.210    (DE) | https://otx.alienvault.com/indicator/ip/81.22.45.210    | BanMalware: normshield_high_attack.ipset      |
62x        | 185.153.196.142 (MD) | https://otx.alienvault.com/indicator/ip/185.153.196.142 | BanMalware: firehol_level3.netset*            |
42x        | 92.63.196.17    (RU) | https://otx.alienvault.com/indicator/ip/92.63.196.17    | BanMalware: normshield_high_attack.ipset      |
33x        | 89.248.162.168  (NL) | https://otx.alienvault.com/indicator/ip/89.248.162.168  | BanMalware: normshield_high_attack.ipset      |
21x        | 185.176.27.118  (BG) | https://otx.alienvault.com/indicator/ip/185.176.27.118  | BanMalware: normshield_high_attack.ipset      |
Top 10 Blocks (Outbound);
2x         | 8.8.8.8         (US) | https://otx.alienvault.com/indicator/ip/8.8.8.8         | ManualBan: ffffffffffffffffffffffffffffffffff |
Top 10 IOT Blocks (Outbound);
Top 10 Blocked Devices (Outbound);
| Hits |   | | Local IP |     | | Device Name |
2x         | 192.168.1.100    | Skynet-PC
[#] 161532 IPs (+0) -- 1841 Ranges Banned (+0) || 2908 Inbound -- 0 Outbound Connections Blocked! [stats] [29s]
It is something specifically with using plink. If i run it locally through putty its fine. But plink picks up the animated green moving *.
@ECHO OFF
plink.exe -load "mpu.cbn.lan" -T "sh /jffs/scripts/firewall stats | sed -r 's/'$(echo -e "\033")'\[[0-9]{1,2}(;([0-9]{1,2})?)?[mK]//g' | strings" > output.txt
"C:\Program Files\Notepad++\notepad++.exe" output.txt
Guess I need to mess with the regex to pull that out too.
@ECHO OFF
I don't use plink so its probably specific to that client. But yes you can just add another sed command to the pipe and filter out whatever specific strings are showing up
Messy but it works.
@ECHO OFF
plink.exe -load "mpu.cbn.lan" -T "sh /jffs/scripts/firewall stats | sed -r 's/'$(echo -e "\033")'\[[0-9]{1,2}(;([0-9]{1,2})?)?[mK]//g' | sed '/#/d' | sed 's/\[1;31m//' | sed '/\[1;32m/d' | strings" > output.txt
Thanks for the link to the post to get me going in the right direction.
Why does skynet only add the first ip range and skips the rest? As far as I can tell the file is correctly formatted: https://raw.githubusercontent.com/vic958420/IPBlockList/master/ipaddresses.txt
