Skynet Skynet - Router Firewall & Security Enhancements
It’s not the first time the function of Ban AIProtect has been misunderstood, Adam. Would something like “Add AIProtect bans” or “Include AIProtect bans” or something similar be more self-explanatory?
In hind sight maybe, but if someone can't take the time to read the documentation I don't think the name of a feature is too important.
I did search.
Pray tell, where is this ‘documentation’?
I have obviously spectacularly failed to find it........
466D564C-D1AE-47C3-AB7E-5BC408495A21.jpeg Since enabling Skynet I’m getting lots of CAPTCHA from various website. Even got it just now when accessing this site. Is someone else going experiencing similar issues. Don’t see anything weird in logs.
View attachment 17338 Since enabling Skynet I’m getting lots of CAPTCHA from various website. Even got it just now when accessing this site. Is someone else going experiencing similar issues. Don’t see anything weird in logs.
Not at my end. Have you tried disabling Skynet and seeing if it makes a difference? I presume your ISP gives you an IP address that changes every few days; if so, can you force a new IP address by shutting down your modem and/or router for a while? It might be that your current IP address has previously been associated with spamming or other bad stuff.
Unrelated to Skynet, that's cloudflares spam protection, your IP is probably flagged by them for whatever reason.
I did search.
Sorry that wasn't a dig at you, it was more a general observation that names of software/scripts/features don't necessarily correlate to their functionality. You can find the documentation on the second post of this thread or in the GitHub readme
I have now tried looking, this time with my eyes open!
Thank you again for your patience, (& Skynet) - outstanding. :)
If I decide later that I want to remove Skynet, is there a command that would I would need to run in order to uninstall it. I see there are commands to run in order to initiate it after pluging in the usb drive. My question is how would one undo that.
Look at #15
Select Menu Option:
[1]  --> Unban
[2]  --> Ban
[3]  --> Banmalware
[4]  --> Whitelist
[5]  --> Import IP List
[6]  --> Deport IP List
[7]  --> Save
[8]  --> Restart Skynet
[9]  --> Temporarily Disable Skynet
[10] --> Update Skynet
[11] --> Settings
[12] --> Debug Options
[13] --> Stats
[14] --> Install Skynet
[15] --> Uninstall
[r]  --> Reload Menu
[e]  --> Exit Menu
[1-15]:
Thanks Guys. I have Skynet up and running. I have been running Pi-Hole as my DNS server. Is there any reason why I shouldn't continue to run Pi-Hole along side of Skynet now?
Honestly mate, once I had diversion, skynet, freshqos, and a few others, I straight up pulled my Pi off my network. This does everything the Pi does.
Find a new use for the pi in my opinion.
I don’t suppose anyone out here could help me get this installed on a GT-AC5300??? No Merilin :((
Asus GT-5300
TP-Link T2600G-18TS, TP-Link, Archer A7
Splunk 7.2.6, Homemonitor 4.5.1, Splunk Stream
Asus GT-5300
No, RMerlin firmware is not offered on any of the GT models. :(
Hello, Skynet is somehow blocking steam.
What do I have to whitelist to use steam?
Do you also happen to have Stubby DNS installed? In my experience, that was the script causing issues with Steam - not Diversion or Skynet.
