See post #2 in this thread.Hi
what's the syntax to ban two countries?
Just list the country digraphs with spaces between them. For example, I have "cn il ir kp ru tw ua"Hi
Hi, new Skynet user. In the Merlin Firewall/General tab, should the Enable Firewall be set to Yes or No? Also, is there a FAQ on Skynet somewhere?
Yes, enable firewall.
FAQ, Not as such, most issues have been well & truly covered in this thread though.......![]()
The first 2 posts are where to start.Thanks for answering. As for all the answers being in the thread instead of a FAQ, yeah.. but this thread is over 5200 posts!
Thanks for answering. As for all the answers being in the thread instead of a FAQ, yeah.. but this thread is over 5200 posts!![]()
does skynet allow importing of list of domains for ip blocking?Without the output from top or htop like suggested above the CPU usage could be caused by anything![]()
If you look at the screen capture in post #1, you will see this:does skynet allow importing of list of domains for ip blocking?
[5] --> Import IP List
@Butterfly Bones , I think you miss-understand me. I was asking if it was already a feature as I am new to using skynet. I was wondering because the two post, as you mention, leave a lot to question more than it answers. I would settle for a simple no.If you look at the screen capture in post #1, you will see this:
Also post #2 has a huge amount of info for those seeking Skynet features.Code:[5] --> Import IP List
Adamm,I suggest using Diversion in conjunction with Skynet for DNS based blacklisting.
But after rebooting the router and restarting my PC I can still ping and access cnn.com from chrome and ping. Any idea what I did wrong?
No just cnn.com I will try www.cnn.com tonight not talking about diversion more so skynet. How can I be sure the firewall-start etc were all setup correctly? Should I try uninstall reinstalling skynet for it to remake the files.Did you add both the naked domain and the www versions? Because the naked domain seems to redirect to the www version for me. And both are handled as separate domains in blocking.
FWIW I use cnn as a test for adblocking because it's such a monster offender in terms of advertisements.
[i] Monitoring From To
[i] 0 Block Events Detected
[i] 0 Unique IPs
[i] 4 Manual Bans Issued
151.101.193.67 is in set Skynet-Whitelist.
151.101.193.67 is in set Skynet-Blacklist.
151.101.193.67 is NOT in set Skynet-BlockedRanges.
Whitelist Reason;
Blacklist Reason;
"ManualBanD: www.cnn.com"
Associated Domain(s);
cnn.com
[i] IP Location - United States (Fastly / AS54113)
[i] 151.101.193.67 First Tracked On
[i] 151.101.193.67 Last Tracked On
[i] 0 Blocks Total
Event Log Entries From 151.101.193.67;
Dec 10 22:51:44 Skynet: [Manual Ban] TYPE=Domain SRC=151.101.193.67 Host=www.cnn.com
First Block Tracked From 151.101.193.67;
50 Most Recent Blocks From 151.101.193.67;
Btw i tried www.cnn.com and still no dice. I did stats and got the following, is something setup wrong ( I never added cnn.com to a whitelist only a blacklist)?
Code:[i] Monitoring From To [i] 0 Block Events Detected [i] 0 Unique IPs [i] 4 Manual Bans Issued 151.101.193.67 is in set Skynet-Whitelist. 151.101.193.67 is in set Skynet-Blacklist. 151.101.193.67 is NOT in set Skynet-BlockedRanges. Whitelist Reason; Blacklist Reason; "ManualBanD: www.cnn.com" Associated Domain(s); cnn.com [i] IP Location - United States (Fastly / AS54113) [i] 151.101.193.67 First Tracked On [i] 151.101.193.67 Last Tracked On [i] 0 Blocks Total Event Log Entries From 151.101.193.67; Dec 10 22:51:44 Skynet: [Manual Ban] TYPE=Domain SRC=151.101.193.67 Host=www.cnn.com First Block Tracked From 151.101.193.67; 50 Most Recent Blocks From 151.101.193.67;
The Fastly CDN is whitelisted by default. There’s an option to disable CDN whitelisting, but that could lead to more unintended blocking.Btw i tried www.cnn.com and still no dice. I did stats and got the following, is something setup wrong ( I never added cnn.com to a whitelist only a blacklist)?
Welcome To SNBForums
