Jack Yaz
Part of the Furniture
it's not available anywhere publicly yet, don't worryahh, I load it with amtm, I'm not even sure what to do with above. I guess I'll have to wait.
Of course, but from what I learned here remote SSH via Dropbear is already a lot safer than remote web GUI (and maybe a bit extra because I use keys instead of passwords for SSH).May I suggest you not turn on SSH from WAN, and instead VPN in first![]()
They no longer use an ASUS router, but the one from their ISP instead.If they can setup a DDNS name for their WAN IP, you can add that name to your whitelist.
Worse: I added their current IP to the whitelist, and while it did not change, I got banned again today, when trying to log in remotely from their location.I’m not sure whether it would help, because I believe SkyNet uses the IP address instead of the DNS name when whitelisting.
(I'm experimenting with SSH keys, so I'm doing a lot of consecutive logins in a short amount of time)
Here's another 2020 spoiler
Happy New Year!
Yes, may a different kind of firewall protect all our friends down under!You're ahead of all of us. Hope the bush fires don't bother you too much and rain is coming your way soon.
SSH exposed to WAN, but I did not have 5 failed attempts.Are you using a VPN or do you have SSH exposed to WAN? If the latter, Skynet hijacks the SSH BFD (brute force detection) and will blacklist you if you hit 5 failed attempts in 60 seconds.
i fully support this idea.any objections if i dabble with a uiSkynet similar to the diversion stats, when 384.15 lands?
I know nothing about the mystery tab that has been shown in a couple of screenshotsi fully support this idea.
Hi @Adamm thanks for creating such an awesome script! Just sent a donation to your account.
With the country ban, is there a way to block inbound connection only (from the countries selected)? and not both connections.
Last time I applied a couple of countries, and I was not able to access some websites (most likely because their server is located on the countries I banned).
Today I started using NextDNS.io as my DNS over TLS server. This worked fine for a couple of hours, until suddenly domain name resolving completely stopped. It started working again when I temporarily disabled SkyNet and immediately broke again when I re-enabled SkyNet. The strange thing is that there are no SkyNet (debug) logs whatsoever when domain name resolving fails.
Yesterday when I was still using Cloudflare (and Quad9) I also had a lot of domain name resolving issues, but I did not think of disabling SkyNet. Maybe that was related, maybe not.
When there are no debug logs, what can I do to investigate/fix this?
I would like to use both NextDNS and SkyNet at the same time...
Welcome To SNBForums
