Skynet Skynet - Router Firewall & Security Enhancements
Hi Adamm and @Jack Yaz
I am having the same issue as @Treadler .
Skynet tab will not show. Force update on Skynet and connmon multiple times.
Connmon tab is showing and working most of the time but will sometimes display the wrong page.
RT-AC86U 384.15_alpha1-g4fecf771de
https://pastebin.com/ayL1gPhB
Hope these logs will provide a clue.
As always, thank you for all of your hard work!
There was a bug I identified in Jacks scripts which I believe to be the root cause, please update them accordingly and reboot.
I've also pushed v7.0.7
Significiantly improve debugging output and include WebUI tests
Notify user logging needs to be enabled for WebUI stats
I have now updated both scripts but skynet is now unable to start.
IPSets | [Failed]
IPTables Rules | [Failed]
IPSets | [Failed]
Whats the full output of;
sh /jffs/scripts/firewall debug info
Deleted
sh /jffs/scripts/debug info
I have no debug file in that location. (sh: can't open '/jffs/scripts/debug')
I ran a fore update again and rebooted. Skynet is now running but still no tab in UI.
Ran print debug info from menu and got:
| Test Description |                | | Result |
Internet-Connectivity               | [Passed]
Write Permission                    | [Passed]
Firewall-Start Entry                | [Passed]
Services-Stop Entry                 | [Passed]
Service-Event Entry                 | [Passed]
SWAP                                | [Passed]
Cron Jobs                           | [Passed]
IPSet Comment Support               | [Passed]
Log Level 5 Settings                | [Passed]
Duplicate Rules In RAW              | [Passed]
IPSets                              | [Passed]
IPTables Rules                      | [Passed]
Local WebUI Files                   | [Passed]
Mounted WebUI Files                 | [Passed]
MenuTree.js Entry                   | [Passed]
| Setting |                         | | Status |
Skynet Auto-Updates                 | [Enabled]
Malware List Auto-Updates           | [Enabled]
Logging                             | [Enabled]
Filter Traffic                      | [Enabled]
Unban PrivateIP                     | [Enabled]
Log Invalid Packets                 | [Enabled]
Ban AiProtect                       | [Enabled]
Secure Mode                         | [Enabled]
Fast Switch List                    | [Disabled]
Syslog Location                     | [Default]
IOT Blocking                        | [Disabled]
Country Lookup For Stats            | [Enabled]
CDN Whitelisting                    | [Enabled]
Display WebUI                       | [Enabled]
15/15 Tests Sucessful
sh /jffs/scripts/firewall debug info - Is what I meant (which it seems like you figured out :p)
Are you sure your looking under the right tab? The tests all passed meaning it should be there (its listed under the firewall section of the WebUI)
Along with the recent contents of your syslog (all entries not just Skynet related)
Hello ...
After the automatic update to v.7.0.6 and now v7.07 there are again hundreds of messages in the syslog. How can I permanently turn them off?
Jan  6 12:40:04 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=213.217.0.5 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=39 PROTO=TCP SPT=45869 DPT=3348 SEQ=448501796 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:40:10 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=37.49.230.200 DST=84.157.149.23 LEN=442 TOS=0x00 PREC=0x00 TTL=57 ID=48953 DF PROTO=UDP SPT=5337 DPT=6063 LEN=422 MARK=0x8000000
Jan  6 12:40:11 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=37.49.230.200 DST=84.157.149.23 LEN=442 TOS=0x00 PREC=0x00 TTL=57 ID=49164 DF PROTO=UDP SPT=5736 DPT=6062 LEN=422 MARK=0x8000000
Jan  6 12:40:12 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=185.209.0.32 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=45085 PROTO=TCP SPT=57035 DPT=10101 SEQ=3131048575 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:40:15 Skynet: [#] 151323 IPs (+0) -- 1636 Ranges Banned (+0) || 14 Inbound -- 0 Outbound Connections Blocked! [debug] [15s]
Jan  6 12:40:27 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=92.119.160.143 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=36745 PROTO=TCP SPT=59883 DPT=58632 SEQ=3164471190 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:40:44 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=92.118.160.45 DST=84.157.149.23 LEN=44 TOS=0x00 PREC=0x00 TTL=247 ID=54321 PROTO=TCP SPT=52223 DPT=444 SEQ=3526350361 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
Jan  6 12:40:48 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=45.136.108.116 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=56325 PROTO=TCP SPT=53579 DPT=7480 SEQ=1601721386 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:40:48 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=185.176.27.170 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=37246 PROTO=TCP SPT=45121 DPT=37935 SEQ=424251462 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:41:06 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=45.136.108.124 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=18396 PROTO=TCP SPT=51752 DPT=7155 SEQ=3201943864 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:41:06 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=37.49.230.200 DST=84.157.149.23 LEN=442 TOS=0x00 PREC=0x00 TTL=57 ID=56443 DF PROTO=UDP SPT=5874 DPT=6064 LEN=422 MARK=0x8000000
Jan  6 12:41:08 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=121.201.67.60 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=7475 PROTO=TCP SPT=49063 DPT=1433 SEQ=887459261 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:41:21 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=37.49.230.200 DST=84.157.149.23 LEN=441 TOS=0x00 PREC=0x00 TTL=57 ID=58678 DF PROTO=UDP SPT=5504 DPT=6066 LEN=421 MARK=0x8000000
Jan  6 12:41:33 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=37.49.230.200 DST=84.157.149.23 LEN=442 TOS=0x00 PREC=0x00 TTL=57 ID=60173 DF PROTO=UDP SPT=5945 DPT=6065 LEN=422 MARK=0x8000000
Jan  6 12:41:34 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=77.247.110.144 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=41885 PROTO=TCP SPT=44369 DPT=3386 SEQ=1874279344 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:41:47 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=213.217.0.5 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=39881 PROTO=TCP SPT=45869 DPT=6027 SEQ=2835159381 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan  6 12:41:58 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=45.136.108.123 DST=84.157.149.23 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=63428 PROTO=TCP SPT=50645 DPT=7063 SEQ=840333636 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Hello ...
That’s the logging output Skynet produces to generate stats, Skynet prunes these logs every hour and moves them to their own file.
I’m surprised you’ve only just noticed this now but this can be disabled by disabling logging under settings.
Sorry, I deleted my post because when I updated my AX88U (Skynet) to v7.0.7, I was getting the same errors. Namely: IPSets | [Failed] &
IPTables Rules | [Failed].
However, after I did a forced install and waited for MUCH longer than is the norm, all started working again.
I have also updated my parents AC87U remotely, and had the same issue. But, again, resolved now after another force install and patients!
FYI. I know that the Skynet UI is not available on the AC87U as it is running an unsupported version of Merlin.
Thank you for your feedback. :)
But if I turn off the logging in the settings, does this mean that statistics are no longer displayed in the WebUi?
I find so same many messages in the syslog very confusing, and other entries may be lost. That's why it bothers me.
Correct.
I find so many messages in the syslog very confusing, and other entries may be lost. That's why it bothers me.
Skynet purges the syslog every hour or whenever you manually run a command.
Thank you.
Perhaps this will be revised or changed in one of the upcoming versions. Preferably without constant messages in the syslog but with the great statistics overview in the WebUi.
Thank you.
Unfortunately this is impossible to avoid without using another script like Scribe to manage your syslog.
is there plan to generate stats in some time interval as is in diversion ?
They are automatically refreshed every 12 hours and when the script starts up.
Hi Adamm,
I am having trouble getting WebUI tab working. My router is RT-AC86U:
Skynet Debug output:
Router Model; RT-AC86U:
Skynet Version; v7.0.7 (06/01/2020) (ff67de781a07394e8c6c36f1a6a77953)
iptables v1.4.15 - (eth0 @ 172.16.100.1)
ipset v6.32, protocol version: 6
IP Address; (1.65.217.249)
FW Version; 384.14_0 (Dec 13 2019) (4.1.27)
Install Dir; /tmp/mnt/sda1/skynet (137.9G / 145.7G Space Available)
SWAP File; /tmp/mnt/sda1/myswap.swp (256.0M)
Uptime; 0 days, 1 hours, 42 minutes.
Ram Available; (174M / 430M)
SWAP | [Passed]
IPSets | [Passed]
Mounted WebUI Files | [Failed]
MenuTree.js Entry | [Failed]
Logging | [Enabled]
Log Invalid Packets | [Disabled]
Ban AiProtect | [Disabled]
13/15 Tests Sucessful
[#] 160302 IPs (+0) -- 1596 Ranges Banned (+0) || 39 Inbound -- 0 Outbound Conn]
and AMTM output showing I have all latest versions applied:
amtm 3.0 by thelonelycoder
RT-AC86U (aarch64) FW-384.14 @ 172.16.100.1
The SNBForum Asuswrt-Merlin Terminal Menu
2 open Skynet v7.0.7
4 open YazFi v3.2.2
j1 open connmon v2.2.0
j2 open ntpMerlin v2.2.0
ep manage Entware packages
sw manage Swap file /mnt/sda1 256.0M
Also tried rebooted the router but the WebUI tab does not show up in Firewall section.
Not sure what caused:
I am having trouble getting WebUI working. My router is RT-AC86U:
SWAP | [Passed]
IPSets | [Passed]
Logging | [Enabled]
4 open YazFi v3.2.2
You need the newest alpha build for your router. 384.15_Alpha1
Dear all,
I observed a stange behavior with skynet in combination with the x3mrouting script. After updating skynet the specific routing to the different vpnclients worked normally. After rebooting, all traffic was through VPN1 , although mostly should be routed to VPN4.
If I force skynet to update again, the orgininal (wanted) situation is there again, till I boot the router again.
I first thought it was a change in the x3mrouting script, but it seems to be, that I could be related with the latest changes in skynet (maybe)?
Any idea what could happen or what I could test to get it done without any additional manual work after rebooting of the router ?
(If you restart Skynet via AMTM it works at it should. Could there be a conflict with x3mrouting?)
Thanks a lot for your support.
Hugo.
