Joshuajackson
i cant find that firmware anywhereOnly works with 384.15 alpha 1
Try looking in "Test Builds."i cant find that firmware anywhere
ive already said it which was a RT-AC68ULast time: What router do you have?
https://onedrive.live.com/?authkey=!AGY2taGX02nVmWA&id=CCE5625ED3599CE0!1427&cid=CCE5625ED3599CE0
The ability for developers to have a tab in the webui was just introduced in this new version. Either install or wait for the stable release of 384.15that alpha update fixes the issue? how come it doesnt work with the latest builds?
i installed it and still not anywhere to be seen ill uninstall skynet again and reinstall it maybe that will helpThe ability for developers to have a tab in the webui was just introduced in this new version. Either install or wait for the stable release of 384.15
Reinstall is a must do.i installed it and still not anywhere to be seen ill uninstall skynet again and reinstall it maybe that will help
Welcome to the forum!yay it works now. Never thought it was the firmware cuz everything else works including the other scripts and they show in WebUI too
Yeah well ive tried googling this but got no info of this problem which was kinda odd. Thanks though. Also this may or may not be in the right forum to ask. But is it possible that Skynet could result in a ping spike because in games such as modern warfare my ping spikes to 999 pretty often. I havent been able to figure out what the problem could be.Welcome to the forum!![]()
No Skynet has no effect on ping time.Yeah well ive tried googling this but got no info of this problem which was kinda odd. Thanks though. Also this may or may not be in the right forum to ask. But is it possible that Skynet could result in a ping spike because in games such as modern warfare my ping spikes to 999 pretty often. I havent been able to figure out what the problem could be.
any idea what it could be? ive installed everything that is in amtm.No Skynet has no effect on ping time.
That may be the issue right there. You should only install what you need to use. These tools in AMTM are useful to people that know how to use them. Some are more friendly than others. Skynet and Diversion don't take much work for the average user, however they are very powerful in their own respect. None of this has been really tested on all devices using all scripts. You may want to reset the router to defaults. Setup from scratch without importing any settings. Add back each AMTM script, and test. When the ping spike returns, stop, and back up.any idea what it could be? ive installed everything that is in amtm.
ok ill do that thanks for your help.That may be the issue right there. You should only install what you need to use. These tools in AMTM are useful to people that know how to use them. Some are more friendly than others. Skynet and Diversion don't take much work for the average user, however they are very powerful in their own respect. None of this has been really tested on all devices using all scripts. You may want to reset the router to defaults. Setup from scratch without importing any settings. Add back each AMTM script, and test. When the ping spike returns, stop, and back up.
You must've developed a great deal of patience dealing with customers like this, who seem ungrateful and unappreciative of the generous help they're getting. I would've stopped responding long agoAh, you edited your previous post.
Make sure you use the latest (Jan 1) Alpha build if you intend to test.![]()
No one on this site is a customer, we are simply fellow firmware users sharing knowledge. If you like the items you use including the firmware, please donate to the appropriate author.You must've developed a great deal of patience dealing with customers like this, who seem ungrateful and unappreciative of the generous help they're getting. I would've stopped responding long ago![]()
Welcome To SNBForums
