Skynet Skynet - Router Firewall & Security Enhancements
Go into Skynet settings again and just re-enable WebGUI. It will integrate everything again. It didn't show up for me just by upgrading to 384.15, probably because I didn't have logging enabled beforehand.
I didn't need to enable the WebGUI when I upgraded it was already on the Tab showed up in the firewall section as soon as the firmware update was done. So I guess it varies?
  • Like
Reactions: a5m
Did you have Skynet logging enabled before the upgrade? I didn't.
Dumb suggestion, as I know Skynet is proper to the firewall, but my OCD still think the Skynet GUI tab should be under the new Addon tab.
I just updated amtm, connmon, ntpMerlin and uiDivStats. Afterwards, Skynet was not OK.
Router Model; RT-AX88U
Skynet Version; v7.0.10 (09/02/2020) (e53ffd1de8c29a1577bab9eb82ab8a4b)
iptables v1.4.15 - (eth0 @ 192.168.50.1)
ipset v6.32, protocol version: 6
FW Version; 384.15_0 (Feb 8 2020) (4.1.51)
Install Dir; /tmp/mnt/ent/skynet (1.6G / 1.9G Space Available)
SWAP File; /tmp/mnt/swp/myswap.swp (512.0M)
Uptime; 0 days, 0 hours, 12 minutes.
Ram Available; (362M / 882M)
| Test Description |                | | Result |
Internet-Connectivity               | [Passed]
Write Permission                    | [Passed]
Firewall-Start Entry                | [Passed]
Services-Stop Entry                 | [Passed]
Service-Event Entry                 | [Passed]
SWAP File                           | [Passed]
Cron Jobs                           | [Failed]
NTP Sync                            | [Passed]
IPSet Comment Support               | [Passed]
Log Level 5 Settings                | [Passed]
Duplicate Rules In RAW              | [Passed]
IPSets                              | [Failed]
IPTables Rules                      | [Failed]
Local WebUI Files                   | [Passed]
Mounted WebUI Files                 | [Failed]
MenuTree.js Entry                   | [Failed]
Diversion Plus Content              | [Passed]
| Setting |                         | | Status |
Skynet Auto-Updates                 | [Enabled]
Malware List Auto-Updates           | [Enabled]
Logging                             | [Enabled]
Filter Traffic                      | [Enabled]
Unban PrivateIP                     | [Enabled]
Log Invalid Packets                 | [Enabled]
Ban AiProtect                       | [Enabled]
Secure Mode                         | [Enabled]
Fast Switch List                    | [Disabled]
Syslog Location                     | [Default]
IOT Blocking                        | [Disabled]
Country Lookup For Stats            | [Enabled]
CDN Whitelisting                    | [Enabled]
Display WebUI                       | [Enabled]
12/17 Tests Sucessful
[*] Rule Integrity Violation - [ #1 #2 #3 #4 #5 #6 #7 #8 #16 #17 #18 #19 ]
[*] Mounted File Missing - [ skynet.asp stats.js chartjs-plugin-zoom.js hammerjs.js ]
I uninstalled Skynet and reinstalled from amtm and Skynet is OK.
My Gut reaction was also to look at the tools menu for it, but I think it makes sense for it to be in the firewall section.
What new Addon tab? I don't have one.
Look at post 6022
The addon tab is not a default tab, its added by Jacks ui* scripts.
In future all you need to-do is check the syslog for the error reason there. In 99.9% of cases a reinstall (while it may end up working) is unnessesary.
Now that i've upgraded i'm see duplicates
The first 2 don't work as you can't expand the tabs the other ones work fine.
Going to uninstall NTP merlin and uiDivstats and resinstall them that is how I fixed this before.
Dud you try a reboot?
No since the router is already been up 18+ hours on the new firmware I'd rather just uninstall and reinstall them. Already done for uidivstats so that is working now to fix NTP merlin.
Thanks for the headsup! I updated ntpMerlin a few hours ago and I also had a duplicate tab there. Uninstalling ntpMerlin and rebooting got rid of the two tabs from the GUI, but now I can't reinstall it from amtm:
ntpMerlin: Unsupported firmware detected - ntpMerlin requires 384.XX
ntpMerlin: Requirements for ntpMerlin not met, please see above for the reason(s)
I have the same issue I posted it in the NTP merlin thread. Working on this now trying to fix.
  • Like
Reactions: ika
Mine is up for about 16 hours, no hiccups.....Thanks for the tip.. Worked here(uidivstats)
Thank you very much
I want to block the country using skynet on only one Windows server device. Is this possible?
Thank you very much
Unfortunately not, any blocks will apply to your whole network.
The duplicate tabs and other issues disappeared after a reboot.
All seems to be working well.
I've pushed v7.1.0
chart.js v2.7.3 ==> v2.9.3
chartjs-plugin-zoom v0.7.0 ==> v0.7.5
fwiw; Any duplicate tab issues are todo with Jack's scripts not Skynet. We specifically account for this during the update process.
