L&LD
Part of the Furniture
@Ola Malmstrom, see the amtm Step-by-Step Guide in the link in my signature below.
The script is in /jffs. The logs and ipset data are on USB.Just logged into my router and found that Skynet wasn't installed. I thought it wasn't deleted if a re-initialize was initiated?
Can anyone tell me how long it should take for the for Skynet statistics to appear in the GUI? I installed Skynet earlier this evening, but the graph areas are just blank and if I click on Update Stats, nothing happens except that I can no longer scroll down the page or leave it other than by using the browser back button. The same thing happens whether I use Firefox or Microsoft Edge.
[i] Custom Filter Detected: https://pastebin.com/raw/A4ur1PwW
[i] Downloading filter.list | [1s]
[i] Refreshing Whitelists | /opt/bin/skynet: line 5613: can't fork
[36s]
[i] Consolidating Blacklist | *--
[i] Refreshing Whitelists | /jffs/scripts/firewall: line 5613: can't fork
[74s]
[i] Consolidating Blacklist | [56s]
[i] Filtering IPv4 Addresses | [12s]
[i] Filtering IPv4 Ranges | [1s]
[i] Applying New Blacklist | [32s]
[i] Refreshing AiProtect Bans | [4s]
[i] Saving Changes | [13s]
I just updated skynet and then did a malware blacklist update:
Code:[i] Custom Filter Detected: https://pastebin.com/raw/A4ur1PwW [i] Downloading filter.list | [1s] [i] Refreshing Whitelists | /opt/bin/skynet: line 5613: can't fork /opt/bin/skynet: line 5613: can't fork /opt/bin/skynet: line 5613: can't fork [36s] [i] Consolidating Blacklist | *--
Edit:
Tried again, now this:
Code:[i] Custom Filter Detected: https://pastebin.com/raw/A4ur1PwW [i] Downloading filter.list | [1s] [i] Refreshing Whitelists | /jffs/scripts/firewall: line 5613: can't fork [74s] [i] Consolidating Blacklist | [56s] [i] Filtering IPv4 Addresses | [12s] [i] Filtering IPv4 Ranges | [1s] [i] Applying New Blacklist | [32s] [i] Refreshing AiProtect Bans | [4s] [i] Saving Changes | [13s]
wc -l /jffs/addons/shared-whitelists/*
sh /jffs/scripts/firewall debug info
106 /jffs/addons/shared-whitelists/shared-Diversion-whitelist
37 /jffs/addons/shared-whitelists/shared-Skynet-whitelist
14 /jffs/addons/shared-whitelists/shared-Skynet2-whitelist
157 total
Here is the output of the first command:
Here is the output of the second command:Code:106 /jffs/addons/shared-whitelists/shared-Diversion-whitelist 37 /jffs/addons/shared-whitelists/shared-Skynet-whitelist 14 /jffs/addons/shared-whitelists/shared-Skynet2-whitelist 157 total
# Router Firewall And Security Enhancements #
# By Adamm - https://github.com/Adamm00/IPSet_ASUS #
# 14/02/2020 - v7.1.0 #
Skynet Version; v7.1.0 (14/02/2020) (eb5d4309f9ee97a8e9adfa3961916774)
iptables v1.4.15 - (ppp0 @ 192.168.1.1)
ipset v6.32, protocol version: 6
IP Address; (185.xxxxxx)
FW Version; 384.15_0 (Feb 11 2020) (2.6.36.4brcmarm)
Install Dir; /tmp/mnt/USB/skynet (3.1G / 3.7G Space Available)
SWAP File; /tmp/mnt/USB/myswap.swp (256.3M)
Uptime; 1 days, 20 hours, 32 minutes.
Ram Available; (90M / 249M)
| Device Name | | | Local IP | | | MAC Address | | | Status |
xxxxxx | 192.168.1.40 | 8c:xxxxx | Inactive
xxxx | 192.168.1.151 | e0:xxxxxx | DELAY
xxxxxx | 192.168.1.172 | 50:xxxxxxx | Online
| Test Description | | | Result |
Internet-Connectivity | [Passed]
Write Permission | [Passed]
Firewall-Start Entry | [Passed]
Services-Stop Entry | [Passed]
Service-Event Entry | [Passed]
SWAP File | [Passed]
Cron Jobs | [Passed]
NTP Sync | [Passed]
IPSet Comment Support | [Passed]
Log Level 5 Settings | [Passed]
Duplicate Rules In RAW | [Passed]
IPSets | [Passed]
IPTables Rules | [Passed]
Local WebUI Files | [Passed]
Mounted WebUI Files | [Passed]
MenuTree.js Entry | [Passed]
Diversion Plus Content | [Passed]
| Setting | | | Status |
Skynet Auto-Updates | [Enabled]
Malware List Auto-Updates | [Enabled]
Logging | [Enabled]
Filter Traffic | [Enabled]
Unban PrivateIP | [Enabled]
Log Invalid Packets | [Disabled]
Ban AiProtect | [Enabled]
Secure Mode | [Enabled]
Fast Switch List | [Disabled]
Syslog Location | [Default]
IOT Blocking | [Disabled]
Country Lookup For Stats | [Enabled]
CDN Whitelisting | [Enabled]
Display WebUI | [Enabled]
17/17 Tests Sucessful
[#] 276814 IPs (+0) -- 1833 Ranges Banned (+0) || 412 Inbound -- 0 Outbound Connections Blocked! [debug] [5s]
sh /jffs/scripts/firewall debug swap uninstall
sh /jffs/scripts/firewall debug swap install
I have had a 512 MB swap file on my utilities USB for well over a year. With your advice, trying to remove and reinstall to 1 GB, I get this error. AMTM will not remove the existing swap file either, Now what?I've been able to further isolate fork errors down to swap file size, increase your swap file to at-least 1GB (this will be enforced in future updates).
Code:sh /jffs/scripts/firewall debug swap uninstall sh /jffs/scripts/firewall debug swap install
Feb 15 07:09:15 RT-AC86U-4608 Skynet: [*] Restoring Damaged Swap File ( /tmp/mnt/SNB/myswap.swp )
Feb 15 07:09:18 RT-AC86U-4608 Skynet: [*] Lock File Detected (start skynetloc=/tmp/mnt/SNB/skynet) (pid=25526) - Exiting (cpid=25862)
I had this problem last night. I was trying to downsize from 2gig to 1gig swap and ended up having to format and reinstall everything.I have had a 512 MB swap file on my utilities USB for well over a year. With your advice, trying to remove and reinstall to 1 GB, I get this error. AMTM will not remove the existing swap file either, Now what?
I can reformat the drive and reinstall everything if needed, I keep multiple backups on my main computer (Linux - to retain all permissions).Code:Feb 15 07:09:15 RT-AC86U-4608 Skynet: [*] Restoring Damaged Swap File ( /tmp/mnt/SNB/myswap.swp ) Feb 15 07:09:18 RT-AC86U-4608 Skynet: [*] Lock File Detected (start skynetloc=/tmp/mnt/SNB/skynet) (pid=25526) - Exiting (cpid=25862)
I had this problem last night. I was trying to downsize from 2gig to 1gig swap and ended up having to format and reinstall everything.![]()
I installed and uninstalled using Skynet. Rebooted and the swap was still there just disabled. If you let's say go into AMTM and type "sw" it will ask if you want to create a swap you answer yes and it creates rather quickly...lol the swap you had without and option to resize or rename or anything.Can't reproduce this on my end, what tool did you use to create the swap files? Also what is the output of the swap uninstall command?
But, only 27MB are used in swap file. See screenshot.I've been able to further isolate fork errors down to swap file size, increase your swap file to at-least 1GB
rm: can't remove '/tmp/mnt/USB/myswap.swp': Operation not permitted
Further to above if I try using Skynet to recreate the now removed swap, the script just reloads to the AMTM menu.Can't reproduce this on my end, what tool did you use to create the swap files? Also what is the output of the swap uninstall command?
It was either Skynet or AMTM, over a year ago, maybe closer to two years. The "lost+found" directory that Linux adds to a formatted drive is dated Mar 26 2018. The swap file itself is dated Jan 5 2019.Can't reproduce this on my end, what tool did you use to create the swap files? Also what is the output of the swap uninstall command?
[*] Pre-existing SWAP File Detected - Exiting!
Swap file found at:
Delete the Swap file? [1=Yes e=Exit]
Swap file deleted:
Added missing swap file entry to
/jffs/scripts/post-mount
I just posted this directly above your reply.You don't have to remove anything. Go to AMTM and delete swapfile from there, then you hit i in AMTM select swapfile and create new 1GB swap. That's it that's all...
Swap file found at:
Swap file deleted:
Why should I increase it to 1GB?
Did you delete file from within Skynet or AMTM? If you deleted withing Skynet you will need to reboot and then do as mentioned with AMTM. All you're doing with AMTM and what's necessary is to delete and expand swapfile. The reason it doesn't work through Skynet is because the swapfile is being used because you're already in Skynet UI. Hope this helps...I just posted this directly above your reply.
If I use the "sw" command in AMTM and choose 1=Yes
I get thisCode:Swap file found at: /tmp/mnt/SNB/myswap.swp Delete the Swap file? [1=Yes e=Exit]
Code:Swap file deleted: /tmp/mnt/SNB/myswap.swp Added missing swap file entry to /jffs/scripts/post-mount
Welcome To SNBForums
