Joshuajackson
Yeah it was set to "router" then i tried Quad9 just now and it seemed to have fixed that problem no idea why, i put in the quad9 dns in manually in wan
@Joshuajackson the scripts you are using together are not meant to be used together.
I think you may need to do some additional research on what each of these scripts does?
If I'm not mistaken, Unbound and DNSCrypt should not be used together.![]()
Do you know which one is better?
