Skynet Skynet - Router Firewall & Security Enhancements
Okay good so that rules out quite a few functions, what about the following command;
sh /jffs/scripts/firewall debug genstats
Adam this time around it took about 4 min to complete.
[i] Generating Stats For WebUI
[#] 147535 IPs (+0) -- 1785 Ranges Banned (+0) || 863 Inbound -- 0 ]
teymur88@router:/tmp/home/root#
Regards
Teymur
Send me a copy of your stats.js file and skynet.log
This is due to one of the YazFi compatibility changes which in turn broke other usage, I'll be reverting this commit shortly and working on (or dropping all-together) YazFi support another day.
I still cannot account for any lock files taking excessive amounts of time, for anyone affected does this happen when you manually run banmalware or the restart commands? Hopefully I will be back to a somewhat normal schedule this weekend, moving has been eating up all my free time :rolleyes:
What's the official way to get skynet.js and skynet.log to you? Both file extensions are unacceptable in Upload a file. I can change the extension to .txt but the logfile at 7.6MB, is too large to be uploaded.
Pastebin, google drive, dropbox... Whatever works.
Regards
Teymur
Okay so thats most likely the issue, now update to 7.1.3 and try;
sh /jffs/scripts/firewall settings lookupcountry disable
FYI, you may want to maximize your terminal window, your output is being cut off (including the script timer!)
Missed that part sorry, that was done from a phone. I'm very remote now and don't always have a pc access. Here is the actual output:
[#] 147535 IPs (+0) -- 1785 Ranges Banned (+0) || 905 Inbound -- 0 Outbound Connections Blocked! [debug] [202s]
Updating to 7.1.3 now.
it's very fast now!
[#] 147534 IPs (+0) -- 1785 Ranges Banned (+0) || 3 Inbound -- 0 Outbound Connections Blocked! [debug] [13s]
Many thanks, Adam.
skynet.js is at https://www.dropbox.com/s/igdbh8nmk8nym9b/skynet.js?dl=0
skynet.log is at https://www.dropbox.com/s/tq1zgnbjs7gbo34/skynet .log?dl=0
So, looks like the issue with the speed is to do with generating the stats? I'm on 7.1.3 and ran the genstats with debug on, took about 5 mins (certainly faster than before) but they all say "no data..."
Updated to Skynet Version; v7.1.3 (13/03/2020) (98ed3362458908cb350851ecf11a8c25).
But after updating it still took some 6 minutes to get rid of the red&yellow "Lock File Detected" phase
[*] Lock File Detected (start skynetloc=/tmp/mnt/ASUS_ENTWARE/skynet) (pid=9290)
[*] Locked Processes Generally Take 1-2 Minutes To Complete And May Result In Temporarily "Failed" Tests
IPTables Rules                      | [Failed]
and eventually get "all green". That is some 4 minutes more than a month ago or so.
it's very fast now!
Same here, it takes 6 minutes.
These issues are all related and are due to ipapi.co and their API failing / being rate limited. Something must have changed recently on their end. I will investigate and/or try find an alternative.
I posted a hotfix in an attempt to fix the issue above. We seem to be getting rate limited based on our useragent, so I changed it :p
Any feedback would be appreciated.
Hi Adam,
I’ll try that now to see what happens. Do I enable the country lookups again and run the commands you told me yesterday?
Regards
Teymur
Hi Adam,
Regards
Teymur
Correct, enable country lookups then use the genstats command.
This is the output now with country lookups enabled:
[#] 149108 IPs (+0) -- 1866 Ranges Banned (+0) || 13 Inbound -- 0 Outbound Connections Blocked! [debug] [35s]
Great its fixed, until they realize what I did to bypass their rate limiting :p
Cool man! Thanks a lot![emoji3][emoji106]
Regards
Teymur
Best approach, however, would be to have a conversation with them to see if there's an amicable solution to using their API :)
We are well within their 30k per month limit, I actually implemented the update frequency around this value. I assume the changes made on their end were unintended.
