Skynet Skynet - Router Firewall & Security Enhancements
is it possible to only unblock a port with skynet? I cannot seem to be able to find a way to just say add a rule to allow port 443 or 80 access. I am currently just manually doing it with iptables in the firewall-start but would like to keep it in a single "firewall" manger if I can. I know i can allow an IP on said ports, but i cant seem to simply be able to allow a port and keep all the logging and other useful bits of skynet that it would provide by using it to do the rule.
Skynet is an IP based blacklisting solution, we don't currently support any specific port features.
  • Like
Reactions: a5m
I have this question right now. For me it is the UDP 1149 port for my OpenVPN server that is always blocked: $
But unfortunately the Adamm only says IP based.
@Adamm does Skynet requires "Logged packets type" set to Dropped/Accepted/Both under Firewall/General settings?
Yes, dropped or both. Skynet will automatically change this
Figures :D I changed it to "None" and it came back. Should've known - IT IS Skynet, always takes over :D:D
  • Like
Reactions: a5m
Hi, I'd like to use an anonymizers and open proxies blocklist on all but a a couple of devices on my network. Is it possible to whitelist clients from blocklists within Skynet or is this something I'd have to set up manually in IPTables? Doesn't really matter either way, I just wanted to check before I started tinkering.
I have to say I LOVE your product.
I've just purchased a ubiquiti usg. Any change you have an idea to make this work on my new Ubiquiti USG?
Happy to donate to the cause. :)
K.
I would replace the USB. They are cheap. Disk check may not reveal failing memory cells.
Speaking of failing memory cells...
Suddenly my swap file started failing:
I first noticed a failed swap about a week ago, but thought it would have been a temporary glitch after updating firmware and rebooting etc.
However, it happened again. I have my swap file located on a separate usb flash drive and I think it might be corrupted or failing. Especially, because I have noticed some other random glitches lately, for example this weird "Lock File detected" case:
So, in order to try to fix the situation I decided to delete the current swap and create a new one to another usb flash drive.
To do so I was going to temporarily disable first Diversion and then Skynet.
I disabled Diversion and after that went to Skynet settings to disable Skynet as well. Now, magically, swap seemed to work again. There was no "SWAP Failed" any more and router GUI showed a swap again:
Anyway, I created a new swap, activated Diversion and Skynet again and rebooted the router. So far so good. But we'll see...
Do you think all these symptoms were caused by a failing usb flash drive and failing swap file?
Lock file is normal few minutes after reboot. Coming and going swap isn’t. There is nothing to diagnose so much on a USB stick. Just replace it. No need to use separate USB for swap.
Yeah, I know. But this Lock File had appeared maybe 48 hours after reboot. And after rebooting or cold start I always login with PuTTY and check that everything is OK, and especially that Skynet is up and running (= everything is green). And and of course I check for updates too.
By the way, I happened to notice this swap problem while I was testing JuiceSSH - SSH Client which I just installed to my Android phone. Seems to be a pretty handy app, especially if you save your "Connection" and "Identity".
https://play.google.com/store/apps/details?id=com.sonelli.juicessh&hl=en
Just occurred to me that I have a passive usb 2.0 hub (4 ports) connected to the usb 3.0 connector of my router. And normally I have two usb flash drives connected to the hub. And this arrangement has worked fine for years now. But lately I installed NVRAM Save/Restore Utility to a third usb flash drive which I randomly connect to the hub as well.
Maybe there won't be enough juice for all of them to work nicely and maybe this has caused the corruption? I just updated the NVRAM Save/Restore Utility yesterday and took some backups... :oops: :rolleyes:
The usb hub has a power supply too, but I haven't used it. :)
With all those USB drives and a hub you only create more points of failure.
I have read (heard rumors) that some cheap usb hubs with power supply might kinda leak current to PC or in this case router. And this "backflow" could even cause some damage? But you could prevent that from happening with a tiny modification (= cutting some wire)?
That's why I prefer having my hub passive, without power supply. And the usb 3.0 connector (which should provide 900 mA) seems to be enough to feed the hub + 2 pieces of usb 2.0 flash drives (each 500 mA max.?).
But maybe the third flash drive is too much? Could the excessive need of current cause damage to the usb 3.0 port of the router? Hard to say how much current each usb 2.0 flash drive will drain.
Sorry for the off-topic, btw...
Hi guys i have problems with skynet - playing up and not recognizing my usb devices i presume swap file gets corrupted for some unknown reason. I do shut down my device every evening and when i power it up every morning the fight with skynet begins - sounds like a movie plot i know. Deleting the swap file and re-creating it does the job but thats too much to be done every single morning. Note that i've tried different USB devices so deff. not from "bad" usb. I can see other people are complaining from the same issues. Thank you!
Just curious, is there any benefit to using a separate USB stick for the swap file? I never heard of someone setting up SkyNet that way.
Do you have Disk check script activated?
At least with my system (too many usb flash drives connected :p) Disk check normally seems to last too long and the swap won't be ready soon enough to get Skynet up and running normally. So after rebooting or cold start of the router I have to [8] Restart Skynet very often to get it going "all green".
I originally had a 256 MB swap file on my Entware flash drive. But after Skynet was updated so that 1 GB swap file was needed, I changed my swap to another usb flash drive simply because then there was not enough disk space in the original location (I only have 8 GB flash drives :) and some video material on those drives as well), so I just decided to move swap to another drive (which happened to have more gigabytes left/free then).
My experience with swap in another partition from SkyNet is that occasionally swap would mount first and SkyNet would not start on reboot.
The most reliable configuration is to have swap and SkyNet on a small filesystem, let's say 2 GB and have the rest in another filesystem.
You cannot unmount the swap/SkyNet filesystem. I configure it to be fsck'd every boot. It takes seconds on a fast drive.
You can umount, fsck and mount the other filesystem while the router is running. I configure this filesystem to never automatically fsck on boot.
I get this message for the last two weeks when updating the Malwarebanlist
Refreshing Whitelists | du: : No such file or directory
When I print the debug info it passes all tests.
Diversion is on its most current release.
