Skynet Skynet v7 web UI not displaying any statistics
Hello, after factory reset and 3 days ontime, no stats in the GUI.
ASUS@RT-AX86U-8860:/tmp/home/root# grep -ow "skynetloc=.* # Skynet" /jffs/scripts/firewall-start 2>/dev/null | grep -vE "^#" | awk '{print $1}' | cut -c 11-
/tmp/mnt/12345/skynet
ASUS@RT-AX86U-8860:/tmp/home/root# ls -l /tmp/mnt/*/skynet/skynet.log
-rw-rw-rw-    1 ASUS     root             0 Mar 22 11:53 /tmp/mnt/12345/skynet/skynet.log
ASUS@RT-AX86U-8860:/tmp/home/root# head -n 5 /tmp/mnt/*/skynet/skynet.log
ASUS@RT-AX86U-8860:/tmp/home/root# tail -5 /tmp/mnt/*/skynet/skynet.log
ASUS@RT-AX86U-8860:/tmp/home/root# ps ww | grep logd
 1463 ASUS      3424 S    /sbin/syslogd -m 0 -S -O /tmp/syslog.log -s 512 -l 7
 1465 ASUS      3424 S    /sbin/klogd -c 5
1820860 ASUS      5976 S    grep logd
ASUS@RT-AX86U-8860:/tmp/home/root# nvram get message_loglevel
5
ASUS@RT-AX86U-8860:/tmp/home/root# nvram get log_level
7
Does your WAN IP (as shown in the GUI) start with 10, 172, 192.168, or 100?
Yes: WAN IP is 192.168.178.7
Router Model; RT-AX86U
Skynet Version; v7.5.8 (07/02/2024) (5c986a1d7fc19ea042ddf1b97ffad170)
iptables v1.4.15 - (eth0 @ 192.168.1.1)
ipset v7.6, protocol version: 7
IP Address; (192.168.178.7)
FW Version; 388.6_2 (Feb 26 2024) (4.1.52)
Install Dir; /tmp/mnt/12345/skynet (52.3G / 57.4G Space Available)
SWAP File; /tmp/mnt/12345/myswap.swp (2.0G)
You won’t see any inbound blocking when this router is behind another router and its firewall.
hello,
for me too: Skynet tap under Firewall in my router GUI all of the drop-downs say "No Data to Display"
I try skynet to: restart, force update, reinstall, but nothing changes!
hello,
Example Debug Commands:​
  • firewall debug info: Print useful debug info.
hello,
| Test Description | | | Result |
Internet-Connectivity | [Passed]
Write Permission | [Passed]
Config File | [Passed]
Firewall-Start Entry | [Passed]
Services-Stop Entry | [Passed]
Service-Event Entry | [Passed]
Profile.add Entry | [Passed]
SWAP File | [Passed]
Cron Jobs | [Passed]
NTP Sync | [Passed]
IPSet Comment Support | [Passed]
Log Level 3 Settings | [Failed]
Duplicate Rules In RAW | [Passed]
IPSets | [Passed]
IPTables Rules | [Passed]
Local WebUI Files | [Passed]
Mounted WebUI Files | [Passed]
MenuTree.js Entry | [Passed]
| Setting | | | Status |
Skynet Auto-Updates | [Enabled]
Malware List Auto-Updates | [Enabled]
Logging | [Enabled]
Filter Traffic | [Enabled]
Unban PrivateIP | [Enabled]
Log Invalid Packets | [Disabled]
Import AiProtect Data | [Enabled]
Secure Mode | [Enabled]
Fast Switch List | [Disabled]
Syslog Location | [Default]
IOT Blocking | [Disabled]
IOT Logging | [Enabled]
Country Lookup For Stats | [Enabled]
CDN Whitelisting | [Enabled]
Display WebUI | [Enabled]
17/18 Tests Sucessful
tnanks
You changed your syslog settings at some point…resulting in your problem.
hello, personally I did not change anything! all I did: was the UPDATE of the router, everything was fine before. then UPDATE of the "addons".
- and whas is the solution !? for this please "Log Level 3 Settings | [Failed]"
regards
dos protection on firewall side, I've seen this problem with vpn and dos protection on. stats will not show if dos protection is enabled.
my "DOS" protection isn't actived
Read the posts on the previous page related to the syslog settings.
hello,
i have put my "syslog settings": whis "debug" and "warning", i will see..
thanks
[EDIT] but afer 1 day, but I still don’t have a "no data to display"
