no, its the 192.168.50.167. Looking at the nvram get custom_clientlist lots of STALE entries all with this name 192.168.50.117 dev br0 lladdr but different IPs but same name. After restoring router again and replacing USB freshly formatted with EXT4 and SkyNet installed no Im only getting just a few results shown, as seen below but the sys log shows a lot more blocking. Any way to flush the these Stale entries? I kind thought by restoring and wiping the USB (SWAP) would do this ? I had a simular problem with Skynet Statistics not showing up and ending being a bad USB but I was able to rule that out by buying new ones and testing them.Is ideapad-laptop the last entry in the list fromnvram get custom_clientlist
If so, I think it’s a problem when the IP isn’t present inip neighoutput, but Skynet doesn’t check for an empty MAC result before searching thecustom_clientlist. Then you always get the last entry fromcustom_clientlist.
Just a theory.
