Hi.
I recently had a USB drive fail that had all of my usual scripts installed one of which was Skynet. This means that I couldn't cleanly remove this script. I have now purchased a new USB, plugged into the router and formatted etc. I see that under 'amtm', the 'Skynet' script is still available for selection (Key 2). So when I go to select it, it just keeps repeating the following message
Skynet: [*] USB Not Found - Sleeping For 10 Seconds ( Attempt 1 Of 10 )
I have tried to manually install Skynet via the code syntax found in the original Skynet thread, I'm given the option of selecting available partition. So I go ahead and select my new USB. It then shows "Invalid Partition Number!"
Is there anyway around this? Can I remove Skynet manually somehow so I can then re-install fresh on my new USB?
