Smart connect rules, leave at defaults?
urbanracer34
Hello!
I have an GT-AX6000 and I was thinking of enabling Smart Connect. I am getting tired of having 2 separate SSID, one for 2.5 and one for 5.
The rules that come by default with Smart Connect, are they good enough for most uses?
Thanks!
urban
Yes. But I would advise taking a settings backup before you change anything and before you make changes to the SmartConnect settings.
OK! How do I do that? It's been a while.
EDIT: "Administration - Restore/Save/Upload Setting" Is this the right option?
Hello!
Thanks!
urban
You can combine Ssid and still turn smart connect off - that’s what I do and rely on the devices themselves to choose the right signal. I found smart connect problematic with apple devices especially; they perform better if they make the choice.
Enabling the WiFi Agile Multiband setting may help too.
I have many apple devices so that can be a problem with enabling smart connect.
How do I combine the SSID again?
Options:
1. Smart Connect enabled; define same SSID for each WLAN. Clients band steer, subject to Smart Connect.
2. Smart Connect disabled; define same SSID for each WLAN. Clients band steer.
3. Smart Connect disabled; define different SSID for each WLAN. User band steers/segregates clients/traffic.
You are not combining SSIDs... you are only naming them the same or differently. When named the same, clients only display them as one connection option (so-called 'combined').
OE
This is the option I would pick. How do I do this? It's been a while.
Just do it... it's obvious... disable Smart Connect and enter the same SSID name for each WLAN.
You may discover a particular client will not cooperate as you would like... i.e., connects to the unpreferred band, which is why Smart Connect exists.
OE
