SMB2
Yes between guest account permissions, different behaviour between windows 8.1 / 10 was a nightmare to get to the bottom!! thanks for your help
Asus RT-AC88U with SMB2.0 enable + client Windows 10 Pro with SMB 1.0 disabled (for security), samba share of router is accesibe only over IP.
When copying a files speed is often very low, when start copying it's first seconds over 20 MB/s then freezes for 5-10 seconds and than drop <1 MB/s.
Sometimes in logs:
Aug 26 18:31:19 smbd[11418]: [2017/08/26 18:31:18.991236, 0] smbd/smb2_read.c:219(smb2_sendfile_send_data)
Aug 26 18:31:19 smbd[11418]: smb2_sendfile_send_data: sendfile failed for file VIDEO/BDMV/STREAM/1.m2ts (Connection timed out). Terminating
On FTP speed is about 36 MB/s without any issues.
I think SMB 2.0 protocol on Asus RT-AC88U is broken.
P.S.
It's on latest merlin 380.68.
Hi ,
Having problems with cifs mount.
Asus RT-AC66U SMB2 enable.
Using a usb harddrive to record tv from tvheadend (libreelec)
If I enable guest account I can ifs mount and record.
But turning off guest no luck. It will not mount.
Getting this log
"Bad SMB2 signature for message
Sep 11 23:37:01 smbd[2292]: [2017/09/11 23:37:01.237999, 0] ../lib/util/util.c:415(dump_data)"
Attached a screenshot configuration
What firmware version? There are SMB2 fixes in 380.68.
Please post the contents of /etc/smb.conf
Hi Colin,
I m running 380.68
Here is the smb.conf
[global]
workgroup = WORKGROUP
netbios name = RT-AC66U-8898
server string = RT-AC66U-8898
unix charset = UTF8
display charset = UTF8
log file = /var/log.samba
log level = 0
max log size = 5
auth methods = guest
guest account = admin
map to guest = Bad Password
guest ok = yes
encrypt passwords = yes
pam password change = no
null passwords = yes
force directory mode = 0777
force create mode = 0777
max connections = 5
socket options = IPTOS_LOWDELAY TCP_NODELAY SO_KEEPALIVE SO_RCVBUF=65536 SO_SNDB
obey pam restrictions = no
disable spoolss = yes
host msdfs = no
Please post the config that doesn't work, the one with guest access turned off and SMB2 turned on.
Here it is:
[global]
unix charset = UTF8
log level = 0
max log size = 5
security = USER
guest ok = no
map to guest = Bad User
max connections = 5
socket options = IPTOS_LOWDELAY TCP_NODELAY SO_KEEPALIVE SO_RCVBUF=65536 SO_SND $
host msdfs = no
strict allocate = No
wide links = no
bind interfaces only = yes
interfaces = lo br0 192.168.0.2/255.255.255.0
use sendfile = no
map archive = no
map hidden = no
map read only = no
map system = no
store dos attributes = yes
dos filemode = yes
oplocks = yes
level2 oplocks = yes
kernel oplocks = no
enable core files = no
deadtime = 30
load printers = no
printable = no
max protocol = SMB2
smb encrypt = disabled
min receivefile size = 16384
passdb backend = smbpasswd
smb passwd file = /etc/samba/smbpasswd
[BACKUP (at MyPassport)]
comment = MyPassport's BACKUP in WD My Passport 0740
path = /tmp/mnt/MyPassport/BACKUP
dos filetimes = yes
fake directory create times = yes
valid users = admin, test
invalid users =
read list = admin, test
write list = admin, test
[Inspeladtv (at MyPassport)]
comment = MyPassport's Inspeladtv in WD My Passport 0740
path = /tmp/mnt/MyPassport/Inspeladtv
dos filetimes = yes
invalid users =
[Music (at MyPassport)]
comment = MyPassport's Music in WD My Passport 0740
path = /tmp/mnt/MyPassport/Music
dos filetimes = yes
invalid users =
[NyaFilmer (at MyPassport)]
comment = MyPassport's NyaFilmer in WD My Passport 0740
path = /tmp/mnt/MyPassport/NyaFilmer
dos filetimes = yes
invalid users =
[Original (at MyPassport)]
comment = MyPassport's Original in WD My Passport 0740
path = /tmp/mnt/MyPassport/Original
dos filetimes = yes
invalid users =
[TV (at MyPassport)]
comment = MyPassport's TV in WD My Passport 0740
path = /tmp/mnt/MyPassport/TV
dos filetimes = yes
invalid users =
Can you give an example of the cifs mount command you are using.
I have it in
storage-recordings.mount
with this configuration:
[Unit]
Description=test cifs mount script
Requires=network-online.service
After=network-online.service
Before=kodi.service
[Mount]
What=//192.168.0.2/MyPassport/Inspeladtv
Where=/storage/recordings
Options=username=admin,password=xxxxxx
# filesystem type
Type=cifs
[Install]
WantedBy=multi-user.target
Have tried with
[Unit]
Before=kodi.service
[Mount]
Options=username=admin,password=xxxxxx,vers=2.1
# filesystem type
Type=cifs
[Install]
But it will not mount
Make sure your Kodi box does support SMB2. I remember that for a long time, they used an old libsmb version that didn't support SMB2. I don't know if that has since changed.
Sorry I can't recreate the problem, even when I use your config. But then my client isn't Kodi.
Enabling SMB2 support on the router doesn't disable SMB1 support, so I suggest that you try forcing Kodi to use SMB1 instead.
Thanks for taking your time Colin
Linke Loetje Issues setting up Sonos Library under SMB2 - not enough credits Asuswrt-Merlin 2
