[SOLVED] Blocking specific incoming IP addresses
No i wasn't trying it with sh:
admin@RT-AC68U:/jffs/scripts# dos2unix firewall-start
-sh: dos2unix: not found
With sh it gives this:
admin@RT-AC68U:/jffs/scripts# sh dos2unix firewall-start
sh: can't open 'dos2unix'
I have edited the firewall-start file with the built in vi editor (vi firewall-start), deleted the ^M (pressing x) and saved (pressing ZZ), which seems to work fine now. Annoying how Notepad++ saving in Unix format seemingly doesn't work.
I'm sure there will be a way for the firewall-start script to call for a file with blocked IP addresses - similar to this: https://www.rosehosting.com/blog/bl...sses-using-iptables-firewall-in-debianubuntu/, but I have no idea how to do that :rolleyes:
Thanks for your time and pointing me in the right direction. :)
Hmm....seems @RMerlin needs to double check that commit.
Beat me to it as I was typing....
Brute force method.....open in vi and delete the ^M's.... or
cd /jffs/scripts
cat firewall-start | tr -d "\r" > firewall-start.tmp
mv firewall-start.tmp firewall-start
or, there's a sed command I don't remember this late :)
dos2unix is there for me.
Ok...I'm stumped then for this user o_O
Next question would be:
nvram get buildno
nvram get extendno
I've seen quite a few users confusing 378.56 Beta 2 with 378.56_2.
RT-AC68U login: admin
Password:
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Mon Nov  2 14:58:44 UTC 2015
admin@RT-AC68U:/# nvram get buildno
378.56
admin@RT-AC68U:/# nvram get extendno
2
admin@RT-AC68U:/#
Then I don't know why dos2unix is missing in your build. Could be a model-specific issue that was only fixed in the following builds - code trees might have been out of sync.
