[SOLVED] JSON parse failed
I just found out I have to apply the firewall rule again after router reboot for the port to be open again.
Is that normal or is there a way to make it enable automatic after reboot?
Do you have 'Enable JFFS custom scripts and configs' set to 'Yes' under Administration > System?
Then check your syslog to make sure it finds the firewall-start script....will look like this
Dec 31 17:01:04 custom script: Running /jffs/scripts/firewall-start (args: eth0)
Also, just for safety's sake, make sure it's in the right format....run
dos2unix /jffs/scripts/firewall-start
Its there:
Aug 6 00:05:11 custom script: Running /jffs/scripts/firewall-start (args: eth0)
I also run the command.
Then there's a bug in your firewall-start script.....a guess.....take out the tab (or spaces) before the shebang on the first line.
I think you just solved my problem! :)
I removed the space as you suggested, restarted the router and I still have the port open.
Thank you! :-D
