[Solved] Scheduled reboots and other log related questions
That's very good news! Thank you for reporting!
Questions are not stupid.
You are right, the cron job is not saved in the backup configuration.
It works now, Tada. Thank you very much. So, reboot was required with no 3rd original command and 7 is not valid day for Sunday.
One more stupid question from newbie. The cron job will not be saved in backup configuration, Right?
The cron job was lost after router latest software update . Is it normal and I have to proceed with commands after every upgrade?
Not as today.
You need to ask Voxel to add some hook at boot time.
It's absolutely possible, and an area with many future possibilities.
But for now you need to do some manual work after FW updates.
Thank you Maestro,
Is it possible to make it permanent with GUI configuration?
Not as today.
I have sent him a request to add autostart option. Will see
D Solved Bricked RBR50 SOLVED! NETGEAR AC Routers and Adapters (Wi-Fi 5) 2
