[SOLVED] Where is Enable JFFS Partition ?
alienx2
There is no enable JFFS Partition look here:
Bec I want to setup to use script like boot up thing "/jffs/scripts/init-start" i tried many times not working.
Have you tried setting "Format JFFS partition at next boot" to Yes, hit Apply and then reboot?
There isnt any on/off for jffs its always on by default.
i did tried add in services-start where in /jffs/scripts/ :
#!/bin/sh
/opt/bin/nzbget -D -c /opt/etc/nzbget.conf
but its not working when boot.. i tried manual run it was working.
#!/bin/sh
The USB disk isn't mounted yet by the time services-start runs.
i already mount usb 16GB TOSHIBA flash drive.
which one i put in init-start or services-start? or what you suggest?
Try the 'post-mount' script (the mount point is passed as a parameter so you start scripts which may be unique to each disk)
