The router VPN client doesn't support IPv6 neither does YazFi.
Where is the information about that? I've been looking at different VPN providers.
And have been trying to find out how i can use my OVPN service with Merlin. And it seems it works fine with IPV6 as long as i don't enable Yazfi.
Again, it is probably just some setting that i didn't set correctly, but running the VPN with only my clients and not YazFi is actually working well so im a bit confused.
Also tried YazFi without VPN and i get problems directly.
I like the features of YazFi and desperatly want to be able to use it with my Router.
Is it my Router modell Rt-AX86U that is the problem? It's like barely two month old
I will try the instruction that Merlin mentions on the page below as i have seen this on other VPN providers help forum.
....................While writing this post i actually did follow Merlins litle OVPN snippet and it worked fine.
Will next try it with YazFi.
Hi all, i´ve changed my Router from AC68U to AC86U. On my AC68U everything works fine with OpenVPN Client, but only to Merlin FW 380.64_2. Every newer Firmware didn´t work. For my AC86U only exist 382.1. There are Problems, connect the Client to Perfect-Privacy. Original FW doesn´t work too...
www.snbforums.com
Many are moving to Wireguard, which is not the easiest to install on on any Asuswrt or Merlin FW.
I just read a news from my ISPs VPN service that they just did a massive uppgrade in Speed, stability and security and asked their customer to try to move away from OVPN.
My ISP is the company that hosted thepiratebay.
They are all about integrity and keeping their customers anonymous. That's why they are moving in this direction.
I also looked at another popular VPN provider - Mullvad.
They even link to supported routers with Merlin FW (Yes mine is not on the list but it might be (outdated) In the end they explain that if you get an IPV6 leak you could add the commands that Merlin mentions in the link above.
How to setup your Asus router running Merlin to connect to the Mullvad VPN servers.
mullvad.net
Supported router models
Asuswrt-merlin
officially supports the following router models:
- RT-AC66U_B1 (same firmware as the RT-AC68U)
- RT-AC68U (including revisions C1 and E1)
- RT-AC68P (same firmware as RT-AC68U)
- RT-AC68UF (same firmware as RT-AC68U)
- RT-AC87
- RT-AC3200
- RT-AC88U
- RT-AC3100
- RT-AC5300
- RT-AC1900 (same firmware as RT-AC68U)
- RT-AC1900P (same firmware as RT-AC68U)
- RT-AC86U (starting with version 382.1)
- RT-AC2900 (same firmware as RT-AC86U)
- RT-AX88U
- RT-AX56U
- RT-AX58U
- RT-AX3000 (same firmware as RT-AX58U)
I'll get back when trying with YazFi again,
In the meanwhile i must say that i do not know what this is or why it comes up, but it does it only when i have YazFi enabled and are turning on or off the guest wifi in the WebUi or just changing something.
I always activate Chromes "Inspect" when i get this kind of errors, and The routers WebUi seems very unstable and has been like this for me since i got my old AC68U around 2015 or 16. But this is exceptional. I had it in all the betas, in the 386.1 and now in the 1_2 also. Definitely Did a full reset several times and reformatted my Thumbdrive and did the three times remove Jffs. with reeboots and everything.
