Setup
Problems I'm trying to solve:
1) Slow file transfer from Win10 to Thecus: for file transfer from Win10 easystore to the Thecus, max speed I see is ~4Mb/s but it heavily fluctuates between that and a few hundred kb/s with an average of ~2MB/s
2) Slow file transfer from Thecus to direct connected USB easystore
3) Slow wifi internet speed from Win10 to both the Netgear and Linksys routers: 18-27Mbs
For #1 I've tried:
Win10 machine ethernet NIC set to use Google's Public DNS addresses, and disabled LSO IPv4 (IPv6 is not installed)
Using WinSCP to transfer files via ftp between Win10 machine and Thecus. I get the same avg of ~2Mb/s transfer using WinSCP or drag and drop with Win10's File Explorer
For #2 I've tried:
Using WinSCP to transfer files via ftp between Win10 machine and Thecus. I get the same avg of ~2MB/s transfer using WinSCP or drag and drop with Win10's File Explorer
Don't know what else to try
For #3 I've tried:
using inSSIDer Home; however, I just installed it and have not done the work to understand what it's telling me other than the 2.4 signal strength in the room with the Win10 machine is -54 dBm. It has a Co-Channel : 8 and Overlapping: 3. This is for the Netgear router set on Ch 11 which looks to provide the fewest overlaps which I understand to be a bigger issue than co-channels.
I can stand in the room with the Pace and Netgear routers and start a speed test on my iPhone 6S - I get ~60-70Mbs. As I walk toward the room with the Win10 machine the speed drops to ~60Mbs. That test ends, I'm standing in the room with the Win10 machine, I start a new speed test and I get ~18-27Mbs. This appears to be because while I'm standing close to the router I'm on 5GHz and I stay on that while the test completes, while I'm walking to the room with the Win10 machine. Then when I run the speed test again the phone has switched to 2.4GHZ.
If I can sort out #1 and #2 I'd be golden. The only reason I was looking at the wifi issue is because I thought I'd set the Win10 machine to use ethernet for internet and wireless for LAN traffic. It's quite possible I'm SOL on improving the LAN transfer speeds without running cable, but thought I'd ask here before beginning demolition.
- HP laptop
- Win10 Home v1909
- Realtek PCIe GBE Family Controller
- Intel Dual Band Wireless AC3160
- WD easystore external USB connected thru 3.0
- Connection to network: ethernet via TP-Link powerline w/ Gigbit capability**
- Internet speedtest: 75-83Mbs (100Mb down is the ATT plan I'm on)
- VPN installed and running
- AT&T w/ Pace 5268 has direct internet connection and is set in DMZ Plus mode and wireless radios turned off; connected via ethernet to
- Netgear X4S R7800 router*, indicator lights show the connection is gigabit; connected via TP-Link powerline w/ Gigabit capability** to
- Linksys Max-Stream AC200 MU-MIMO Tri-Band (set in reapeater mode) connected thru Netgear GS108 switch (passive) via ethernet to
- Thecus N5550 NAS connected via USB 2.0 to
- WD easystore (NAS is getting full)
* At the Netgear I get 97-99Mbs internet download speed)
** TP-Links are used because there are too many firebreaks to drill through run cable (for now)
The Netgear and Linksys have Smart Connect and Band Steering enabled, respectively (so they decide which band a device connects to depending on signal strength)
For #1 I've tried:
For #2 I've tried:
For #3 I've tried:
