System Error Message
Part of the Furniture
You may not have to use your switch after all. The RB3011 has 10 ethernet ports. Dont however buy from end point shops, buy from suppliers or europe because the prices of hardware in the UK have doubled.
I've heard rumours of vdsl/adsl SFP modules and mikrotik sells GPON SFP modules.
Using a layer 3 switch would work to easily provide the link but you forgot about the QoS i talked about. However using a layer 3 switch will allow inter routing such as for sharing servers much faster than a router. You could also filter the connection with a router as well.
If you use something like mikrotik you dont actually need to use your own router as a router, you could use routerOS interface capability to make it work as both your router and the edgerouter. However you still need to apply a passive vlan to your interface and your interface would also be assigned one of the IPs seperate from the router's IP. You can do this for other clients so no routers are needed but it is better for them to use their routers to control their own network.
