sorry for delay, yes I get the error in the app saying they detected im using the proxy.Everything looks okay to me. I see packets traversing the iptables chain for Amazon but not for Netflix.
Code:17 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set x3mRouting_NETFLIX dst MARK or 0x8000 18 781 191K MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set x3mRouting_AMAZONAWS dst MARK or 0x8000
Try to surf NF in a browser and again on your streaming device and see if the packet count goes up. Do you get the proxy error when try to stream on NF?
Also try adding the router IP to the Policy Rules and route to the WAN per the post above.
I added the WAN entry like your picture for mine, will also reboot the device again and try again. I am in canada so im assuming the netflix IP's in the script cover me, if not then it may not be hitting that rule
Hi, Small Noob Q, is there a way you can make this work like in AMTM? Im reading this and putting some lines from above into Putty but i cant get Netflix to workIf you can make this work i think you make a lot Noobs and experts ( i think) very happy !!
Well, I think were closedid you get through the full setup as well or stuck before the finish line?
I don’t recognize the iptable entries above the ones we created for routing NF. Do you have QoS enabled? They may be interfering. Rather than appending the iptable rules for NF, we can insert the rules so they are at the top. Change the iptables entry in the script from -A to -I.So Interestingly enough.
Downstairs firestick 192.168.50.10 is working in both netflix but amazon prime knows its a proxy, but we dont use downstairs much so im guessing if we watch tv down there alot too it will know and block, since it took a bit for them to block .11 too
upstairs firestick 192.168.50.11 will not work in either netflix or amazon prime
So it is definitely still NATing both netflix AND amazon through the openVPN versus my wan sir
I really do appreciate all of the help
I should note I couldnt do the last step so im manually starting after reboot as i dont have the nat-start option in the scripts location, only IPSET_Netflix.sh post-mount services-start and services-stop
"If the script runs successfully, you can have the script execute at system start-up by calling it from /jffs/scripts/nat-start by including the line sh /jffs/scripts/IPSET_Netflix.sh in the file. Make sure nat-start has a she-bang as the first line in the file #!/bin/sh and is executable e.g. chmod 755 /jffs/scripts/nat-start."
admin@RT-AC86U-6D00:/jffs/scripts# iptables -nvL PREROUTING -t mangle --line
Chain PREROUTING (policy ACCEPT 159K packets, 152M bytes)
num pkts bytes target prot opt in out source destination
1 6308 917K MARK all -- * * 192.168.50.0/24 192.168.50.1 MARK set 0x9
2 6308 917K RETURN all -- * * 192.168.50.0/24 192.168.50.1
3 0 0 MARK all -- * * 0.0.0.0/0 !192.168.50.0/24 MAC D4:E6:B7:C2:8A:0B MARK set 0x1e
4 0 0 RETURN all -- * * 0.0.0.0/0 !192.168.50.0/24 MAC D4:E6:B7:C2:8A:0B
5 26940 7821K MARK all -- * * 0.0.0.0/0 !192.168.50.0/24 source IP range 192.168.50.150-192.168.50.225 MARK set 0x1f
6 26940 7821K RETURN all -- * * 0.0.0.0/0 !192.168.50.0/24 source IP range 192.168.50.150-192.168.50.225
7 61055 7402K MARK all -- * * 192.168.50.10 !192.168.50.0/24 MARK set 0x20
8 61055 7402K RETURN all -- * * 192.168.50.10 !192.168.50.0/24
9 2851 1005K MARK all -- * * 0.0.0.0/0 !192.168.50.0/24 MAC F0:81:73:FC:36:F0 MARK set 0x21
10 2851 1005K RETURN all -- * * 0.0.0.0/0 !192.168.50.0/24 MAC F0:81:73:FC:36:F0
11 691 87716 MARK all -- * * 192.168.50.12 !192.168.50.0/24 MARK set 0x22
12 691 87716 RETURN all -- * * 192.168.50.12 !192.168.50.0/24
13 1333 406K MARK all -- * * 0.0.0.0/0 !192.168.50.0/24 MAC 98:9C:57:ACB:12 MARK set 0x23
14 1333 406K RETURN all -- * * 0.0.0.0/0 !192.168.50.0/24 MAC 98:9C:57:ACB:12
15 0 0 MARK all -- * * 0.0.0.0/0 !192.168.50.0/24 source IP range 192.168.50.60-192.168.50.65 MARK set 0x24
16 0 0 RETURN all -- * * 0.0.0.0/0 !192.168.50.0/24 source IP range 192.168.50.60-192.168.50.65
18 419 111K MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set x3mRouting_AMAZONAWS dst MARK or 0x8000
Thanks for voluntering to be a tester. I made good progress this weekend. Wednesday is a holiday here so I may be able to wrap things up then.let me know if you want a Guinea pig to help install and qa documentation, it honestly wasnt that bad after (not that it worked) the hardest part for me was getting the USB drive ready but google always prevails.
I do not have QOS enabled, the main reason i went with Asus was bandwidth limiter, i love in a location where im capped at slower speeds so i try to control the kids etc.
another thought i had as many firewalls read top down, i wonder if i should have the WAN rule in the VPN NAT first then do the VPN rules as well.
Ill try changing that entry or moving on the method 2 as you suggested, cant thank you enough looking to trying the new model, but this was honestly a great setup, i can maybe from a noob perspective help make it a little friendlier for others if you want
Using the AS number for Netflix, route Netflix traffic to the WAN:
load_ASN_ipset_iface.sh 0 NETFLIX AS2906
Using the IPSET feature in DNSMASQ, route Netflix domains to the WAN:
load_DNSMASQ_ipset_iface.sh 0 NETFLIX amazonaws.com,netflix.com,nflxext.com,nflximg.net,nflxso.net,nflxvideo.net,dvd.netflix.com
Route Amazon Prime to VPN Client 1:
load_AMAZON_ipset_iface.sh 1
Use a list of IP addresses stored in a file located in /opt/tmp to populate the IPSET list CBS and route to VPN Client 5:
load_MANUAL_ipset_iface.sh 5 CBS
Welcome To SNBForums
