Split tunneling based on Application Can it be done?
TechTinkerer
384.16 Alpha 2 rt-ac86u
I'm wondering if Split tunneling based on Application can be added as part of vpn\wan policy routing, so a user can define a list of apps that go over vpn or wan could this be doable?
see this
works on proton vpn they let you add or delete apps that use the tunnel or not
Is that option only available if you are running there app on a PC? Astrill also has that option when using their app but I think what the OP was asking is it possible to do using a VPN client running on their router.
Windscribe does the same, but as im trying to get it to work through android tv (shield tv) windscribe apps lacking to be able to choose the apps or search to add more!
so, was hoping a routing profile per app marked traffic was available that specifies wan or vpn usage through router itself
Yes, i was hoping to do from the router
