I have configured a Rsync-job from a QNap to an Asus router that worked fine untill now. Now it results in an error message:
[Hybrid Backup Sync] Failed to complete Sync job: "Name Job". Encountered error "sh: rsync: not found" Attempting to retry. Error code: 1.
When I test the connection from the QNap Storage Space to the Asus router it shows also an error : Test connection. Permission denied.
The asus log shows a valid login but disconnects:
Jul 18 15:38:05 dropbear[14813]: Child connection from 192.168.1.1xx:40162
Jul 18 15:38:05 dropbear[14813]: Password auth succeeded for 'Asus' from 192.168.1.1xx:40162
Jul 18 15:38:05 dropbear[14813]: Exit (Asus) from <192.168.1.1xx:40162>: Disconnect received
Entware rsync is well installed. Nothing has changed, but the firmware: With Putty I can make a SSH connecttion.
Qnap states the user needs to be entitled to perform SSH encrypted backups jobs.
Can I check that somewhere on the Asus Router ?
Kind regards, Paul
Firmware:
Asus: RT-AX86U_386.7_0
QNap: 5.0.0.2055
Kind regards, Paul
Firmware:
QNap: 5.0.0.2055
