davidstoll
I have 90+ static IP's saved in:
LAN>DHCP Server>Manually Assigned IP around the DHCP list (Max Limit : 128)
When I try to (edit and/or) APPLY the page, I get:
"Resulting list of DHCP reservations is too long - remove some, or use shorter names."
Unfortunately, I can't tell you when this started, but it was one of those things "I would get back to", but since then, I have updated the firmware a few times. I'm on 382.1_2 on my RT-AC88U.
All devices seem to work just fine, but I can't edit that page. Even if I delete a few, it will give me the error. I've used the linux NVRAM script to save the list as a text file and edit it that way, which seems to work fine to "restore" and save the new devices I want to add, so it's the only way to do it at this point.
I've looked for funny characters, but other than letters and numbers (that it might allow entry but then subsequently not like), the only other characters in the names that I have used are underscores and dashes ( _ and -). The longest hostname is 24 characters. Maybe the limit isn't actually 128 static hostnames?
If anyone can help, I would appreciate it.
