static route
eliotte
I'm looking where the config file for static route is located.
On my network, I have 2 other router as vpn. One has a US IP, and the other one Germany IP.
I use dnsmasq and force some domains to get sepcific IP and then, use static routing for sending these traffic to my vpn box.
Probleme is, sometimes, the IP I use for some domains change. So I created a bash script to automaticly do a nslookup and now I want to update automatically my dnsmasq and static routing.
Thanks for your help
So I found my information by myself. File is located here: /proc/net/route. But I found I don't need it.
What I will try to do is to run my script doing nslookup for all my domains and then run, for each domain:
ip route delete old_ip
ip route add new_ip via VPN_LOCAL_IP metric 16
I wil add a cron jod running it each hour so it will be always up to date. I will post all my code when it will be finish.
First, in the same directory of the script following, you need a file called urls.txt as follow:
#gamecenter|10.222.215.80
gamecenter.nhl.com
#hulu|10.222.215.245
t2.hulu.com
p.hulu.com
play.hulu.com
data.flurry.com
This is an exemple for some domains. The ip after | is the getway used for this services. In this exemple, I will route all gamecenter traffic by 10.222.215.80 and hulu by 10.222.215.245
The script use jffs partition and create or add stuf to your dnsmasq.conf.add and /etc/dnsmasq.conf
NOTE: bash is really not a language I use often. Here the code:
#!/bin/sh
#config
dns = "8.8.8.8"
#function
rewrite(){
echo > $1".temp";
wasnotwritten=true;
for i in `cat $1`;
do
        if [[ ${i:0:8} != '#dynamic' ]];then
               	echo $i >> $1".temp"
        else
                echo '#dynamic' >> $1".temp"
                cat ips.txt >> $1".temp"
                wasnotwritten=false;
		break;
        fi
done
if $wasnotwritten ; then
fi
rm $1;
mv $1".temp" $1
#retrive Old IP to remove from static routes and Delete it
for i in `cat ips.txt`;
do
        if [[ ${i:0:1} != '#' ]];then
                ips=$(echo $i | tail -n 1 | cut -d "/" -f 3)
		echo "delete "$i
		ip route delete $ips
        else
                currentgw=$(echo $i | cut -d "|" -f 2);
                currentservice=$(echo $i | cut -d "|" -f 1);
                echo $currentservice >> ips.txt
        fi
done
#NSLOOKUP and add new ips to static route
echo > ips.txt
currentgw = ""
for i in `cat urls.txt`;
do
		ips=$(nslookup $i $dns 2>/dev/null | grep Address | tail -n 1 | cut -d " " -f 3)
		echo "address=/"$i"/"$ips >> ips.txt
		echo "add "$i" $ips";
		ip route add $ips via $currentgw metric 16
	else
	fi
done
#rewrite Config Files
echo "rewrite config files"
rewrite "/jffs/configs/dnsmasq.conf.add"
rewrite "/etc/dnsmasq.conf"
#relaod dnsmasq
echo "reload DNSMasq"
killall dnsmasq
dnsmasq -c 1500 --log-async -n
echo "done!"
Using a cron job, this can update IPs each hours, day, etc..
Simple note, the script must be run in the current directory as:
 ./static_route
If you try to run in a different path like " /path/.../static_route" it will not work.
You can add this line of code at the beginning to fix it:
cd /directory/where/script/is/located
