Strange behaviour of script "app_base_link.sh"
Quadcore
I am an owner of RT-AC86U router with last stable release of RMerlin (384.4.2).
I've an external USB3 HDD with two partitions, first one with NTFS fs, second one with EXT3 fs.
I've installed the Entware packages (32bit) with the newest script and I've installed the same packages I had with my previous router (RT-AC56U) - with my previous router I had firmware Tomato.
The strange behavior is whenever the USB HDD is mounted. Even if in Entware installation I've used commands "chmod" and "chown" to give the proper permissions to some folders/files, after EXT3 partition mounting I've discovered that ALL folders and files have cancelled all my previous "chmod/chown" commands.
This is caused by script "app_base_link.sh", placed in folder "/usr/sbin". This is the code that cancels all my previous "chmod/chown" commands on folders/files - lines 63-78:
APPS_MOUNTED_TYPE=`mount |grep "/dev/$APPS_DEV on " |awk '{print $5}'`
if [ "$APPS_MOUNTED_TYPE" != "vfat" ] && [ "$APPS_MOUNTED_TYPE" != "tfat" ]; then
    if [ "$APP_FS_TYPE" != "fuseblk" ] ; then
        chmod -R 777 $APPS_INSTALL_PATH
    fi
    user_account=`nvram get http_username`
    if [ -z "$user_account" ]; then
        user_account="admin"
    fi
        chown -R "$user_account":root $APPS_INSTALL_PATH
    fi
    rm -rf $APP_LINK_DIR
    ln -sf $APPS_INSTALL_PATH $APP_LINK_DIR
    exit 0
fi
The issue is inside the "if" condition, the code uses "chmod -R 777" starting at root of the Entware's installation path. The same job is done with command "chown", using "admin:root" for all folders/files.
Logically the Entware partition is not of type "fuseblk", it is "ext3", so the "if" condition is always true.
I kindly ask to @RMerlin if it is possible to remove the two lines "chmod" and "chown", leaving the rest of the code, in order to keep the current "chmod/chown" status of all folders/files of Entware installation. Thanks.
Code is here "https://github.com/RMerl/asuswrt-me.../src/router/rom/apps_scripts/app_base_link.sh" and also on ASUSWRT gpl code "asuswrt\release\src\router\rom\apps_scripts".
I imagine the reason for this behaviour is because Asuswrt (perhaps unlike Tomato) is essentially a single-user OS. Everything is expected to be owned and run by the root (usually called "admin") account.
That's why there is no useradd, userdel, usermod, groupadd, groupdel, etc.
Those scripts are used by Download Master, so I don't want to touch them. My advice if you need to customize your environment would be to uninstall Download Master, and setup Entware instead.
This is the same code I've rewritten to solve my problem:
        fi
        usbdisablechmod=`nvram get usbmount_disable_chmod`
        if [ -z "$usbdisablechmod" ]; then
                usbdisablechmod="0"
        fi
           if [ "$usbdisablechmod" == "0" ]; then
           fi
        fi
        exit 0
fi
Value of nvram key "usbmount_disable_chmod"
unset -> run as before
set == "0" -> run as before
set != "0" -> doesn't execute chmod/chown
