D
dixonge
Guest
I've had a Linksys WGA54G connecting my HR20 sattelite box to my 2wire router working for some time now. Recently I decided to add a home-made NAS to the mix and have been experimenting with setup options.
Last night the setup that caused the largest number of devices to show up as being connected to the 2wire was something like this....
2wire -- cat5 -- WGA54G ~~802.11~~ Netgear WGR614v5 --cat5-- FreeNAS box
This seems to be using both the WGA54G and the Netgear wireless router in the exact reverse configuration from what they were intended. It seems like every time I unplug the WGA54G the FreeNAS box drops off the network. But it's hard to tell because the connectivity has been sporadic in general.
I did managed to connect to the FreeNAS WebGUI and setup one hard drive, but that's all so far.
Can someone explain why this worked at all, and if I can even use these wireless routers/adapters like they are currently configured? Better yet, if you have any ideas on connecting my HR20 satellite box and my FreeNAS PC (OLD PC) to my 2wire wirelessly I'm all ears...
