Stuck on OpenVPN: Looking up DNS name
JohnnyBeGood
Hi all,
I already have PPTP server set up successfully and wanted to see if I can get faster connection speed using OpenVPN (although I've read PPTP is faster).
This is what I've done:
1.created user name and password
2. exported OpenVPN configuration file
3. Installed OpenVPN connect app on my S4
4. Imported file into app
When I try to connect it sits on " OpenVPN: Looking up DNS name" after some time it times out. Before I start changing setting that I'm not familiar with what else I need to do?
Open certain ports?
TIA
Sent from my SCH-I545 using Tapatalk
is the server's ip/ddns address in the ovpn? it may be simpler if you could post your configuration. the exported configuration shouldn't have any keys afaik, but if there are, omit them.
assuming you have DDNS setup if you've had PPTP working
Thanks for taking time to reply!
Here's what's in client1.ovpn with X's for private key parts
client
dev tun
proto udp
remote linux 1194
float
comp-lzo adaptive
keepalive 15 60
<ca>
-----BEGIN CERTIFICATE-----
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
ns-cert-type server
resolv-retry infinite
nobind
remote linux 1194
"linux" is not a resolvable name on the Internet. Make sure you enter a FQDN name there which can be resolved over the Internet.
Ok, for pointing it out. I'm using namecheap for my DDNS service and I have mydomain.net registered with them. Ever since I've setup on the main page I get this:
Instead of linux.mydomain.net
Here's the DDNS page:
To solve this issue I could edit client1.ovpn file and change linux into linux.mydomain.net ?
As I said, don't use just "linux" as the hostname, but the FQDN. Have you tried doing that on the DDNS config page too?
Hi RMerlin,
Thanks for all your hard work!
When I enter linux.mydomain.net as hostname under DDNS config page I get error: see below, it accepts only linux and not linux.mydomain.net
Hi RMerlin,
heya, you need to manually edit the OVPN for the destination ip/FQDN.
remote linux 1194 < should read like;
remote linux.mydomain.net 1194 if this is properly yours and being updated with your IP
Howdy. I did that already but when I connect there's no Internet.
assuming you have verified that your DDNS is properly resolving to your WAN IP; try adding the line 'float' to your client OVPN
[edit1] and see attached [/edit2]
[edit2/] it would appear that the OVPN export function already adds float, so nix that, sorry. is your server config set as in the attached image?
Tried just now and I was able to tunnel thru my connection and I had internet!
So, looks like issue was with my DDNS issue that RMerlin pointed out. For whatever reason even after I've changed to linux.mydomain.net I did not had any internet even though I was connected.
I've tried with "Server 2" and left everything at default as I had internet once connected.
