Hi All. For some reason, i am unable to access 2 routers (68u 386.11and ax88u 388.2_2) running the latest Merlin build. I discovered the issue when opening my ASUS router app on my android to check on something (like i obsessively do) App wouldn't connect to either of these routers.
Both units are setup to use https on port 8443 and have been working fine until now. I use asus DDNS service and use the domain names to connect. Both routers are also set to respond to pings and i know that they are online responding to pings. Other apps on my networks are working fine and broadcasting (nest cams etc).
I find it curious that two routers in two locations are having an issue at the same time. If it was just one, i could chalk it up to something random but both of them seem to be a little odd.
Decided to post here to see if anyone has had anything similar happen recently.
