Hello,
I need some help in finding the best solution to the problem that I have on my wlan network.
On the mansard of my house (2nd floor) I have the PC and DSL/WLAN router (http://www.avm.de/en/Produkte/FRITZBox/FRITZ_Box_Fon_WLAN_7390/index.php).
On the ground floor I have a weak or absent wlan signal, and there is located a satellite decoder (Humax iCordHD, it has a 10/100 port) that I would like to connect to the PC.
Unfortunately there is not possible to run ethernet cables from the 2nd floor to the ground floor, and the house is of concrete/stone.
The distance between the PC / router to the center of ground floor is about 10-15m and there is a couple of thick walls in between.
I could place a "wlan device" in the 1st floor, about in the middle of the distance between the router and the satellite decoder.
I was thinking at disable the wlan of the Fritzbox and buy a dedicated wlan router because after trying with a repeater (http://www.avm.de/en/Produkte/FRITZ_WLAN/FRITZ_WLAN_Repeater_300E/index.php) and a powerline device (http://www.avm.de/en/Produkte/FRITZPowerline/FRITZPowerline_500E/index.php) the results were very negative...
I was thinking at buying two ASUS RT-AC66U (or N66U) and place them, one on the 2nd floor as a "main" wlan router and the second on the ground floor as a AP, near the sat. decoder.
Could it be a suitable solution ?
Another thought is to place the second RT-AC66U on the first floor and buy a EA-N66 to connect the sat. decoder on the ground floor.
Could it be possible to make such a network ?
Any suggestion ?
Any suggestion ?
