Support for AC5300 ROG Rapture
Try searching the forums , there must be 50+ posts asking the same thing, the answer is no , it isn't going to happen.
Maybe the 60th time it is asked might yield a more favourable response.
But more likely, the answer will be the same as it always has been, with the frustration level being ratcheted up a bit more.
No, the answer will be the same and if you read some of the previous threads you would see why.
As Merlin has stated many times, both the hardware and software architecture of that model are totally different and there is no way he can produce anything for it.
The situation won't and can't change so "frustration" is pointless.
The list of supported models is plain enough to see , if you choose a different model having been advised it isn't supported, asking 60, 70 or 100000 times won't help .
I am well aware why it isn’t supported. Perhaps you should have directed your quote toward the OP.
Which makes this "" Maybe the 60th time it is asked might yield a more favourable response. "" all the more silly .
Clearly you missed the sarcasm bus here.
Sarcasm doesn't help solving problems. Humour is welcome always and above all humility rules here.
