Hello,
I am new to this forum and tried to find any Information, if the AC66U (with Merlin firmware) does Support DFS & TCP.
I think he means TPC (Transmit Power Control).Not sure what you mean regarding TCP.
802.11h is another standard (other than a,b,g, n,ac) and not seeing it in the references as supported usually means that it is not supported...Hello,
oh, sorry. Yes I mean TPC and DFS are needed to use the upper channels in the 5GHz ....
http://en.wikipedia.org/wiki/IEEE_802.11h-2003
I did not find any information, if the stock firmware does support it....
therefor my question....
Regards
Guny
Well, apart from Wireless > Professional > 5GHz > Regulation mode = 802.11h802.11h is another standard (other than a,b,g, n,ac) and not seeing it in the references as supported usually means that it is not supported...
Hello,
[...]I did not find any information, if the stock firmware does support it....
Regards
Guny
Welcome To SNBForums
