I consider myself fairly technical hence installing Merlin on my Asus but here I'm becoming a bit unstuck and need the support of you experts.. if possible, thank you...
I had a piece of hardware that I've been told by someone who had remote access to the hardware logs, that it's reporting continuous packet loss and high gateway responses. I've got a feeling this is my network but how would I got about detecting the issue?
I have a main router and a AiMesh, both RT-AC68U and it appears to only be the AiMesh router causing the issue, which is wired, via a few switches from the main router.
Attached is the syslog
