rgnldo
No longer. I use OpenBSD. System with its own configuration.To be clear, are you running the Merlin FW version of suricata on an Asus Merlin router?
Suricata 5.0.3 and Talos rules
Latest config entry for IPS
af-packet:
- interface: eth0
cluster-id: 98
copy-mode: ips
copy-iface: br0
use-mmap: no
tpacket-v3: no
- interface: br0
cluster-id: 97
copy-mode: ips
copy-iface: eth0
use-mmap: no
tpacket-v3: no
I changed the af-packet entries back to the original settings. At least I can easily view the suricata logs from the uiScribe log menu to check if it alerts on suspicious activity. I still have no confidence it will block malicious traffic.
Curious, what does your suricata log file show during startup? Does it still show IPS is enabled? Can you paste your log file during startup to share?
No, it no longer indicates IPS mode once I went back to the default config.
Aug 7 05:26:37 RT-AC86U suricata: 7/8/2020 -- 05:26:37 - <Notice> - This is Suricata version 4.1.8 RELEASE
Aug 7 05:26:37 RT-AC86U suricata: 7/8/2020 -- 05:26:37 - <Info> - CPUs/cores online: 2
Aug 7 05:26:37 RT-AC86U suricata: 7/8/2020 -- 05:26:37 - <Info> - Found an MTU of 1500 for 'eth0'
Aug 7 05:26:37 RT-AC86U suricata: 7/8/2020 -- 05:26:37 - <Info> - Found an MTU of 1500 for 'br0'
Aug 7 05:26:37 RT-AC86U suricata: 7/8/2020 -- 05:26:37 - <Info> - stats output device (regular) initialized: stats.log
Aug 7 05:26:37 RT-AC86U suricata[16099]: 7/8/2020 -- 05:26:37 - <Info> - Syslog output initialized
Aug 7 05:26:38 RT-AC86U suricata[16099]: 7/8/2020 -- 05:26:38 - <Info> - 20 rule files processed. 3117 rules successfully loaded, 0 rules failed
Aug 7 05:26:38 RT-AC86U suricata[16099]: 7/8/2020 -- 05:26:38 - <Info> - Threshold config parsed: 1 rule(s) found
Aug 7 05:26:38 RT-AC86U suricata[16099]: 7/8/2020 -- 05:26:38 - <Info> - 3117 signatures processed. 223 are IP-only rules, 567 are inspecting packet payload, 2466 inspect application layer, 0 are decoder event only
Aug 7 05:26:42 RT-AC86U suricata[16099]: 7/8/2020 -- 05:26:42 - <Info> - Going to use 2 thread(s)
Aug 7 05:26:42 RT-AC86U suricata[16099]: 7/8/2020 -- 05:26:42 - <Notice> - all 4 packet processing threads, 2 management threads initialized, engine started.
Aug 7 05:26:42 RT-AC86U suricata[16099]: 7/8/2020 -- 05:26:42 - <Info> - All AFP capture threads are running.
Aug 7 05:50:21 RT-AC86U suricata[16099]: [1:2019284:3] ET ATTACK_RESPONSE Output of id command from HTTP server [Classification: Potentially Bad Traffic] [Priority: 2] {TCP} 192.168.2.1:80 -> 192.168.2.224:50104
Aug 7 05:50:21 RT-AC86U suricata[16099]: [1:2100498:7] GPL ATTACK_RESPONSE id check returned root [Classification: Potentially Bad Traffic] [Priority: 2] {TCP} 192.168.2.1:80 -> 192.168.2.224:50104
Aug 7 08:41:47 RT-AC86U suricata[16099]: [1:2013028:4] ET POLICY curl User-Agent Outbound [Classification: Attempted Information Leak] [Priority: 2] {TCP} 192.168.2.201:57562 -> 45.60.27.121:80
This is what it reported in my prior config using use-mmap: no
Aug 7 05:18:00 RT-AC86U suricata[15140]: 7/8/2020 -- 05:18:00 - <Info> - cleaning up signature grouping structure... complete
Aug 7 05:19:06 RT-AC86U S82suricata: Starting Suricata IDS/IPS /opt/etc/init.d/S82suricata
Aug 7 05:19:06 RT-AC86U suricata: 7/8/2020 -- 05:19:06 - <Notice> - This is Suricata version 4.1.8 RELEASE
Aug 7 05:19:06 RT-AC86U suricata: 7/8/2020 -- 05:19:06 - <Info> - CPUs/cores online: 2
Aug 7 05:19:06 RT-AC86U suricata: 7/8/2020 -- 05:19:06 - <Info> - Found an MTU of 1500 for 'eth0'
Aug 7 05:19:06 RT-AC86U suricata: 7/8/2020 -- 05:19:06 - <Info> - Found an MTU of 1500 for 'br0'
Aug 7 05:19:06 RT-AC86U suricata: 7/8/2020 -- 05:19:06 - <Info> - AF_PACKET: Setting IPS mode
Aug 7 05:19:06 RT-AC86U suricata: 7/8/2020 -- 05:19:06 - <Info> - stats output device (regular) initialized: stats.log
Aug 7 05:19:06 RT-AC86U suricata[15279]: 7/8/2020 -- 05:19:06 - <Info> - Syslog output initialized
Aug 7 05:19:06 RT-AC86U suricata[15279]: 7/8/2020 -- 05:19:06 - <Info> - 20 rule files processed. 3117 rules successfully loaded, 0 rules failed
Aug 7 05:19:06 RT-AC86U suricata[15279]: 7/8/2020 -- 05:19:06 - <Info> - Threshold config parsed: 1 rule(s) found
Aug 7 05:19:06 RT-AC86U suricata[15279]: 7/8/2020 -- 05:19:06 - <Info> - 3117 signatures processed. 223 are IP-only rules, 567 are inspecting packet payload, 2466 inspect application layer, 0 are decoder event only
Aug 7 05:19:10 RT-AC86U suricata[15279]: 7/8/2020 -- 05:19:10 - <Info> - Copy mode activated but use-mmap set to no. Disabling feature
Aug 7 05:19:10 RT-AC86U suricata[15279]: 7/8/2020 -- 05:19:10 - <Info> - Going to use 2 thread(s)
Aug 7 05:19:10 RT-AC86U suricata[15279]: 7/8/2020 -- 05:19:10 - <Notice> - all 4 packet processing threads, 2 management threads initialized, engine started.
Aug 7 05:19:11 RT-AC86U suricata[15279]: 7/8/2020 -- 05:19:11 - <Info> - All AFP capture threads are running.
As I figured:
Code:Copy mode activated but use-mmap set to no. Disabling feature
I do think using it for detection is still good.
What do you think would be the harm using it with my previous config with use-mmap: no settings? Would it still alert only or actually provide reject/drop functions?
I recommend posting the output in a "code" block.
Has anyone actually tested the IPS mode? (Reading rose-colored logs doesn't count).
ISTM that if you can get any one rule to work (actually drops a connection and reports a "drop"), then they all likely work.
http://wrs49.winshipway.com/ (34.211.233.68 52.36.140.135 ) is blocked by aiprotect. Activate aiprotect and try to go there and you'll be blocked; deactivate aiprotect and you can get there - test works.
Do the same test with suricata (obviously after deactivating aiprotect).
Here is a draft suricata "drop" rule for winshipway. Perhaps one of you could create a ruleset folder titled "winshipwaytest"; put this rule in it; activate that folder in the config; and try to browse to http://wrs49.winshipway.com/ . I tried this months ago when I had time to play with suricata and it didn't work - I received an "alert", but the "drop" action had been changed to "alert" despite my specific rule.
Seems that some of you have made good progress and may be able to get this test to work!!
rule:
drop ip [34.211.233.68,52.36.140.135] any <> $HOME_NET any (msg:"test IPS rule connect with wrs49.winshipway.com"; reference:url,doc.emergingthreats.net/bin/view/Main/CompromisedHosts; threshold: type limit, track by_src, seconds 60, count 1; classtype:misc-attack; sid:2500000; rev:5517; metadata:affected_product Any, attack_target Any, deployment Perimeter, tag COMPROMISED, signature_severity Major, created_at 2011_04_28, updated_at 2020_08_06
Note: that last smiley face is actually a "semi-colon close paren" - part of the rule
.I wanted to give that a try (just out of curiosity; I don't think I have IPS working), but NextDNS already blocked the domain name (blocked by "thread-intelligent-feeds").
alert icmp $EXTERNAL_NET any -> $HOME_NET any (msg:"ICMP connection attempt"; sid:1000002; rev:1;)
drop icmp $EXTERNAL_NET any -> $HOME_NET any (msg:"ICMP connection attempt"; sid:1000002; rev:1;)
Aug 7 22:41:29 ac86u suricata[17126]: [1:1000002:1] ICMP connection attempt [Classification: (null)] [Priority: 3] {ICMP} <ip1>:771 -> <ip2>:0
Aug 7 22:42:43 ac86u suricata[17260]: [wDrop] [1:1000002:1] ICMP connection attempt [Classification: (null)] [Priority: 3] {ICMP} <ip1>:771 -> <ip2>:0
af-packet:
- interface: eth0
- interface: br0
Aug 7 22:43:29 ac86u suricata[17369]: [Drop] [1:1000002:1] ICMP connection attempt [Classification: (null)] [Priority: 3] {ICMP} <ip1>:771 -> <ip2>:0
af-packet:
- interface: eth0
copy-mode: ips
copy-iface: br0
use-mmap: yes
tpacket-v3: no
- interface: br0
copy-mode: ips
copy-iface: eth0
use-mmap: yes
tpacket-v3: no
.I recommend posting the output in a "code" block
.I thought I could try your rule by using a different IP, but somehow I don't even get an alert for the IP I use (and the web page just opens).
However, when I changed this test rule:
into:Code:alert icmp $EXTERNAL_NET any -> $HOME_NET any (msg:"ICMP connection attempt"; sid:1000002; rev:1;)
I no longer getCode:drop icmp $EXTERNAL_NET any -> $HOME_NET any (msg:"ICMP connection attempt"; sid:1000002; rev:1;)
butCode:Aug 7 22:41:29 ac86u suricata[17126]: [1:1000002:1] ICMP connection attempt [Classification: (null)] [Priority: 3] {ICMP} <ip1>:771 -> <ip2>:0
with configCode:Aug 7 22:42:43 ac86u suricata[17260]: [wDrop] [1:1000002:1] ICMP connection attempt [Classification: (null)] [Priority: 3] {ICMP} <ip1>:771 -> <ip2>:0
andCode:af-packet: - interface: eth0 - interface: br0
with configCode:Aug 7 22:43:29 ac86u suricata[17369]: [Drop] [1:1000002:1] ICMP connection attempt [Classification: (null)] [Priority: 3] {ICMP} <ip1>:771 -> <ip2>:0
Code:af-packet: - interface: eth0 copy-mode: ips copy-iface: br0 use-mmap: yes tpacket-v3: no - interface: br0 copy-mode: ips copy-iface: eth0 use-mmap: yes tpacket-v3: no
EDIT: Is "wDrop" indeed "would drop"?
Welcome To SNBForums
