Suspected (DNS) exploit kit on ASUS RT-N66U
The difference is between www.google.com and google.com
# nslookup google.com
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 2a00:1450:4009:802::200e lhr25s07-in-x0e.1e100.net
Address 2: 216.58.208.142 lhr25s08-in-f14.1e100.net
Ah, my bad. thanks.
nslookup www.google.com
Server:    127.0.0.1
Address 1: 2a00:1450:400f:805::2004 arn06s07-in-x04.1e100.net
Address 2: 83.140.66.42 83.140.66.42.biz.sta.port80.se
Address 3: 83.140.66.38 83.140.66.38.biz.sta.port80.se
Address 4: 83.140.66.19 83.140.66.19.biz.sta.port80.se
Address 5: 83.140.66.30 83.140.66.30.biz.sta.port80.se
Address 6: 83.140.66.29 83.140.66.29.biz.sta.port80.se
Address 7: 83.140.66.59 83.140.66.59.biz.sta.port80.se
Address 8: 83.140.66.53 83.140.66.53.biz.sta.port80.se
Address 9: 83.140.66.45 83.140.66.45.biz.sta.port80.se
Address 10: 83.140.66.23 83.140.66.23.biz.sta.port80.se
Address 11: 83.140.66.15 83.140.66.15.biz.sta.port80.se
Address 12: 83.140.66.49 83.140.66.49.biz.sta.port80.se
Address 13: 83.140.66.44 83.140.66.44.biz.sta.port80.se
Address 14: 83.140.66.34 83.140.66.34.biz.sta.port80.se
Address 15: 83.140.66.27 83.140.66.27.biz.sta.port80.se
Address 16: 83.140.66.57 83.140.66.57.biz.sta.port80.se
DNS Advantage is fairly solid as a public DNS...
The big concern with Neustar is that they're a primary provider for CALEA (Lawful Intercept)...
hi guys, was this issue resolved? or did you find the root cause for this?
I have experienced the same, my wife reported "google outage" and I started to look around. any DNS query except google was running perfectly fine.
I'm runing 380.63_2, didnt find any suspicious in /etc/dnsmasq.conf or in iptables NAT tables. /tmp/resolv.conf was pointing to my ISP DNS.
now the funny part, I changed "Connect to DNS Server automatically" to NO and set OpenDNS. everything started moving the right way. switched to ISP DNS, and 127.0.0.1 response is back, I could reproduce the problem multiple times in a row.
Unfortunately after about 30 min (and multiple reboots), the response is back to normal and I cannot reproduce the 127.0.0.1 response for google.com anymore to provide a tcpdump or anything similar.
The IT guys from the ISP confirmed that there was no outage on the DNS infra. I will keep an eye on this and get some dumps if time permits.
######## On the router itself:
# nslookup www.google.com
Server: 127.0.0.1
Address 1: ::ffff:127.0.0.1
Address 2: 127.0.0.1 localhost.localdomain
Server: 127.0.0.1
######## I tested DNS lookups on the wifi client, of course it was the same
[21:17:33][Tue Nov 22]:~ dig www.google.com
; <<>> DiG 9.10.4-P3 <<>> www.google.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 17922
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;www.google.com. IN A
;; ANSWER SECTION:
www.google.com. 0 IN A 127.0.0.1
;; Query time: 20 msec
;; SERVER: 192.168.1.1#53(192.168.1.1)
;; WHEN: Tue Nov 22 21:18:05 CET 2016
;; MSG SIZE rcvd: 48
[21:18:05][Tue Nov 22]:~ dig google.com
; <<>> DiG 9.10.4-P3 <<>> google.com
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16826
;google.com. IN A
;; ANSWER SECTION:
;; WHEN: Tue Nov 22 21:18:10 CET 2016
;; MSG SIZE rcvd: 44
Sometimes it's a badly cached record that can cause issues with specific sites. I've seen it happen with a few servers. Windows DNS server for instance is infamous for randomly failing to resolve entire TLDs, until you flush the DNS server cache. Microsoft published a technet article on a way to mitigate the issue through a registry tweak (been years since I've delt with that specific issue, so I can't remember the details.)
If your ISP provides some kind of local cache for Google's servers, the issue might have been at that level, not at the DNS server level.
That TTL of 0 secs is equally interesting there IMHO.
With DNSMasq, to clear the cache, just restart it...
$ sudo /etc/init.d/dnsmasq restart
OR
$ service dnsmasq restart
OR
Those won't work on AsusWRT as they are System V commands. The equivalent is:
service restart_dnsmasq
or
killall -SIGHUP dnsmasq
hi, magic was resolved :) it seems that routing to Google wasnt working correctly for Czech and Slovak republic between 19:30-21:00 CET 22/11/2016 and this was the root cause for the issue.
can be verified by external articles in local language
http://downdetector.com/status/google/news/90156-problems-at-google
http://downdetector.com/status/google/news/89973-problems-at-google
http://dsl.sk/article.php?article=19097
http://www.zive.sk/clanok/121045/google-nefunguje-problemy-maju-aj-dalsie-jeho-sluzby
