Swap file
@Hazel
I'm very Old, as per Master Yoda, so Clark is sticking with the recommended!
Exactly. AC68 has only 256MB of RAM
In fact there is very little difference in available RAM after boot between AC68U and AC86U. With AiProtection and Adaptive QoS both routers have about 120-140MB RAM left. AC86U may have 2x RAM, but the software it is running is also using more RAM.
I am not talking about "plain" router situation. I was specifically referring to the situation when you have several addons running on AC68, especially "heavy" ones like Diversion and Skynet.
Well, when you start with the same RAM available you can fit about the same scripts in it before any swap is used.
