Switch WAN type from SSH
CntrlAltDel
Hi there,
I seem to be struggling trying to get WAN type changes applied through SSH. So far for example I've tried:
Bash:
nvram set wan_proto=pppoe
nvram set pppoe_username='x'
nvram set pppoe_passwd='x'
nvram commit
service restart_wan
But no dice. WAN configs dont change whatsoever in the web gui and if I check with the below I find that DHCP is still set.
Bash:
nvram show | grep wan_proto
I would like to be able to switch to PPPoE and also to DHCP.
Given the number of wan variables available in nvram, I can't say I'm surprised. You're making assumptions that it's just a matter of nvram variables, when such changes might trigger other processes. It might even require a reboot.
Regardless, in a case like this, I always dump nvram both before and after the change and diff the results, just to be sure what actually changed.
DIR='/jffs'
nvram show | sort >/dev/null > $DIR/nvram.before
# make changes via GUI
nvram show | sort >/dev/null > $DIR/nvram.after
diff $DIR/nvram.before $DIR/nvram.after
I used /jffs rather than /tmp in case it requires a reboot after making changes.
