Synology DS-209+ review up!!
Yes DSM 2.2 functionality is all the same for all units "except" the new R/W speeds that changes for every unit it is installed on.
You have updated the 209 & 209+ throughput but you did not update the 409 & 409+ speeds in charts, and speed really increases a lot at least with 409+ witch I own.
Actually the charts shows similar performances for 209+ and 409+ but 409+ has been tested with an older software that is much slower than the new one.
This is what I really meant, sorry if you don´t understand me.
Cheers.
Really? Funny that Synology didn't point out that advantage of DSM 2.2.
Can you please describe the speed increase that you got?
At any rate, I won't be re-reviewing the products.
I don't know what you talk with synology or not, I only tell you the avantages I have noticed, you can believe or of course not.
Synology DSM 2.2 increased read and write rates respect to previous version. In my first post I told you my DS409+ (read) rates with 2.2
There should be a tedious work to update any small change of every unit you test.
Sorry I will not disturb you anymore
Thanks.
