Tcpdump error
Brouno
Hello,
I'm trying to check traffic on WAN intf with tcpdump 4.2.1 / libpcap 1.3.0 from the Entware official repo
I get an error "tcpdump: eth0: SIOETHTOOL(ETHTOOL_GTSO) ioctl failed: Invalid argument"
admin@RT-N66U:/tmp/home/root# opkg install tcpdump
Installing tcpdump (4.2.1-3) to root...
Downloading http://wl500g-repo.googlecode.com/svn/ipkg/openwrt/tcpdump_4.2.1-3_entware.ipk.
Installing libpcap (1.3.0-1) to root...
Downloading http://wl500g-repo.googlecode.com/svn/ipkg/openwrt/libpcap_1.3.0-1_entware.ipk.
Configuring libpcap.
Configuring tcpdump.
admin@RT-N66U:/tmp/home/root# tcpdump -i eth0
I get the same error for vlan1 (normal, vlan1 is same as eth0)
It's working like a charm on eth1, eth2, br0
I read on sourceforge an explanation for the previous version of libpcap, here :http://sourceforge.net/tracker/index.php?func=detail&aid=3572006&group_id=53067&atid=469577
I am using tcpdump 4.2.1 / libpcap 1.2.1 on a BCM4716-based router (mipsel-linux-uclibc, kernel 2.6.23)
Packet capture on vlan interfaces would not start with the following error:
SIOETHTOOL( ETHTOOL_GTSO) ioctl failed: Invalid argument.
This is apparently coming from pcap-linux.c / iface_ethtool_ioctl()
I believe ioctl would return EINVAL if a certain ioctl is not supported by the device, so the code should probably look like
if (ioctl(handle->fd, SIOCETHTOOL, &ifr) == -1) {
if (errno == EOPNOTSUPP || errno == EINVAL) {
This change has fixed the error on my system and I am now able to do packet capture on vlan devices
As I'm not able to check/compile/build package of libpcap (limits of my skills ;-) ), is there someone which get/can compile the libpcap with the patch ?
Or perhap's a link to a repo which get other/correct libpcap version ? (I already tried some, but with no success)
NB : I'm using a RT-N66U with last merlin build Asuswrt-Merlin 3.0.0.4.354.28 Beta 1, but I assume that's not the problem
Thanks a lot :)
I reply to myself for reference.
I finally manage to cross compile libpcap 1.3.0 with the patch referenced in my previous post
Using infos from here : https://github.com/RMerl/asuswrt-merlin/wiki/Compile-Firmware-from-source-using-Ubuntu
& here : http://tiebing.blogspot.fr/2010/12/corss-compile-tcpdump-for-linuxmips.html
and libpcap is now working and able to sniff traffic on eth0 :) (using tcpdump or other tools like darkstat)
the only "drawback" is that my own compiled libpcap is ~540Ko while the "official" one (from repo) is ~220Ko
I suspect some compilation options not very accurate, btw, it's working :)
For those interested just install the official libpcap through optware/entware then replace /tmp/mnt/sda1/asusware/lib/libpcap.so.1.3.0 with this one from my dropbox :
edit : recompilation see below other post : http://forums.smallnetbuilder.com/showpost.php?p=69671&postcount=5
lly says this is a kernel API malfunction in et driver. Better to fix it.
Eric?
I'd have to see if Asuswrt uses a newer closed-source driver or the same open-source code as WL500G.
Currently got my hands full with the debugging of cstats (making a lot of progress thankfully), and with other new toys I got on my hands, so not sure when I'll get the chance to get around to it.
Ok. I've made those workaround in Entware repo because TomatoUSB kernel suffers with this bug too.
Great ! :)
I see the libpcap 1.3.0-1a , already upgrade to this one and ... working ;-)
Thx
