Thanks for fixing the updating problem with 384.10+!
RejZoR
I just want to say thanks for fixing the updating problem where I updated the firmware for RT-AC87U and after process was done, nothing was actually updated. Before I had to reset router to default, update it and load back old settings to complete update which took ages with numerous lengthy reboots, but since 384.10, it's working seamlessly again. I just update it and it works in one go. :)
There was nothing changed to the updating process, that code is actually closed source...
If you have had problems in the past and you reloaded settings from a saved backup then you just reloaded you problems again. At the first sign of trouble be prepared to do a factory default reset and manually reconfigure.
